What is "PCD" when regarding bolt pattern?
Old Jan 13, 2011 | 10:28 PM
Scone's Avatar
So I'm looking at getting some new wheels and I found some I like but I'm not sure if they'll fit and I don't wanna drop the cash and be SOL. So the bolt pattern is 5x114. But it reads as 5x114 PCD. What does this mean? Any help is greatly appreciated. I tried searching but couldn't really find anything.
Scott
Old Jan 13, 2011 | 10:30 PM
4DGS's Avatar
Pitch circle diameter.
Basically the space between the lugs holes.
and it's actually 5x114.3, but 5x114 or 5x115 will fit.
Old Jan 13, 2011 | 10:41 PM
broke_as_ajoke's Avatar
does he need the central ring thing that goes on the hub.. I know I got one when i got my wheels.. it's a piece of hard plastic that goes on b4 u place the rim on the rub.. makes it fit tight
Old Jan 13, 2011 | 11:04 PM
Scone's Avatar
Appreciate it. So these will fit then?
Old Jan 13, 2011 | 11:07 PM
Scone's Avatar
Also, I'm trying to have the wheels sit closer to the outside, would you recommend spacers or wider wheels? They're offering them in 19x9.5 and 19x11
Old Jan 13, 2011 | 11:17 PM
I can only help so much.. cuz when i got my wheels i didn't know much about the wheels.. I have heard a lot from these guys on here, but what i can tell u. I have 20's 9.5 +24 front and 11's +29 in the rear.. i don't need spacers cuz my tires sit in line with the outer fender. You need to find out the offset of the rim's.. my offset is weak compare to some of the guys on here.
Oh and the ring thing is called: Hub Centric Rings 73mm to 66.06mm Plastic (that size was for my wheels it might not be the same for yours)
Old Jan 13, 2011 | 11:28 PM
Scone's Avatar
Awesome, I appreciate the help
Old Jan 14, 2011 | 07:33 AM
grovefromnh's Avatar
Go with the 19" wheels.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
6spdGspot
Oct 5, 2015 01:55 PM
doakley92
Sep 25, 2015 12:58 PM
CrazyLogic219
Sep 24, 2015 09:59 PM
