will 2003 wheels fit on my 2005??
Old Jan 14, 2011 | 06:58 PM
tgoron's Avatar
I have a 2005 G35 with the 19" wheels - looking to buy a set of used wheels on craigs for cheap - they are from a 2003 G. . . am i nuts for thinking they may not fit? 5 " with snow tires!
thanks
Old Jan 14, 2011 | 06:59 PM
MixturePinoy's Avatar
they will fit
Old Jan 14, 2011 | 07:45 PM
tgoron's Avatar
thanks - AAA towed me up my street, the hill is slight enough to leave me in a snow bank so i think it's time for tires!! thanks again!
Old Jan 15, 2011 | 05:14 PM
TofuProductions's Avatar
As long as your blinker fluid is within the proper DOT8 specs, you'll be fine.
Old Jan 17, 2011 | 07:07 PM
tgoron's Avatar
blinker fluid - hahaha.
anyway, the rear went on without a problem but the front seems to be giving me trouble. there is a stud sticking out of the rotor and before i remove it has anybody else removed these studs? they look like a weight or something to keep the rotor seated properly. it sticks out about an inch - can i remove these? front wheels wont go on with them there. thanks!
Old Jan 17, 2011 | 07:12 PM
Frankieg35's Avatar
Yeah that's just so u don't put the print wheels on the back.. u can take it off..
Old Jan 19, 2011 | 08:50 PM
tgoron's Avatar
ok - so the wheels do not clear the brake calipers, they are supposed to be G35 sedan wheels from a 2003. the back fits fine but the front hits the calipers. going to grind a little to see if i can make it work.
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
joedaddy1
Jul 28, 2015 02:58 PM
realtalk21
Jul 20, 2015 09:07 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
