Have anyone try running 20x11 in front coupe?
Old Jan 28, 2011 | 02:09 AM
Bozookah's Avatar
I always wonder if you can actually do this with 20x11 15 offset in the front with full turn lock to lock without rubbing. The wheel I want to get they have 20x9 15 offset but thats kinda weak and probably need spacer to have the flush look in front. So maybe I was thinking getting a set of 4 of 20x11 15offset. Pictures would be helpful if you have the same specs or similar. Thanks
Old Jan 28, 2011 | 02:17 AM
Frankieg35's Avatar
That's kinda wide for the front.. I'd get the others and space them out..
Old Jan 28, 2011 | 02:23 AM
HenryLee's Avatar
I've seen 10.5 all around. Looks good. Doet~
Old Jan 28, 2011 | 04:03 AM
4DGS's Avatar
It will handle like a bag of ***** if you run 11" square.
Just get the 9 and run a 20mm spacer or 25mm spacer.
Old Jan 28, 2011 | 09:26 AM
Kenny_Cox's Avatar
biggest i've seen was 19x10 19x11. it looked awesome, i haven't been here long though.
Old Jan 28, 2011 | 09:38 AM
GreenGoblin's Avatar
The goblin resurrection
Why not buy them in the correct width and offset to begin with. There are zero benefits to running that wide of a front wheel.
Old Jan 28, 2011 | 05:25 PM
Bozookah's Avatar
I guess spacer in the front is the way to go then. I have 25mm spacer all around right now but the cars steering wheel does shake a lil bit when im on freeway so im trying to eliminate the use of spacer as much as possible
Old Jan 28, 2011 | 05:43 PM
you do not need have that wide of a wheel to have big lips if that is what you are trying to do. I have 5" lips on my front wheels for a widebody, and even then I only run 10.5 fronts.
I guess technically you could run 11" front rims, but you would have to get your specs right or I am sure you would rub.
Old Jan 28, 2011 | 07:02 PM
4DGS's Avatar
I have 10s and 11s on my sedan lol
What kind of spacers? I would go that route, far better than going oversized up front just because.
Listen to Danny, he knows wheels better than most on this site.
Old Jan 28, 2011 | 09:49 PM
Bozookah's Avatar
I was going to do 20x9 in front but idk why but I always run into vibrating problem whenever I use spacers, or could it be the spacers themselves? Never had vibration problem before without spacers
Old Jan 28, 2011 | 09:54 PM
broke_as_ajoke's Avatar
bro save ya self the heart ache and just go with 9.5 in the front (that's what i have) and if u want it to stick out pass the fender get u a 25 mm spacer and u will be dead on point..
Old Jan 28, 2011 | 11:22 PM
Bozookah's Avatar
Dude thats not a problem or would it give me headache if they have 9.5. They only have 20x9 and 20x11 both with 15 offset, its not custom wheels where i can just pick my own size lol
Old Jan 29, 2011 | 12:58 AM
HXS's Avatar
HXS
lemme guess... xxr 526?
lol i was thinking the same thing of running 11 up front, but not worth the ****ty handling.
Old Jan 29, 2011 | 03:22 AM
Bozookah's Avatar
shhhhhhhhh it was supposed to be our secret lol
Old Jan 30, 2011 | 12:27 AM
Sylvan lake V35's Avatar
I run 19x10.5 up front, I would say 10" up front would be ideal unless you're going for poke & stretch. Trying to fit 11" inside the factory fenders is going to be very very tight.
