Wheels and tires
Old Nov 4, 2004 | 06:34 PM
smokeator's Avatar
Wheels and tires
After all the looking and searching I have finally found the rims that have called out to me.Now I need some advice. These will be going on a sedan.
Rims are 18 x7.5
Question is what offset would be best they are offered in 35, 42, and 48mm and staggering is not an option.
Also the package comes with 225/40/18 tires, should I pay the extra $200 to upgrade to 245/45/18 tires.
Also will either of these tire configurations change my ECU for the traction control?Thanks
Old Nov 8, 2004 | 12:54 PM
sickpig's Avatar
Re: Wheels and tires
I just put new wheels and tires on my sedan.
18x8's w/ 40mm offsets. 245/45-18 Goodyear GS-D3's. Fit perfectly. The 35 or 42 would work with a 7 1/2" wheel.
Mark
2003 Sedan AT. Sport Aero Ivory Pearl/ Willow
20% tint. Z-tube. Clear Corners w/ PIAA.
Aluminum Pedals
Old Nov 9, 2004 | 07:48 AM
jaspergtr's Avatar
smokeator - i'm not sure if you can put 245's on a 7.5" safely. depends on the maufacturer specs of that specific line. but usually a 245 must go on a 8" or greater. you might do a little better with a 225/45 which is a little smaller, but still good, or a 235/45, which is virtually the exact size of oem, but the tires are expensive.
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
