soo i want to go 18x10 all around too
im slammin the car. so i should go r. 225 45 18 and f 225 40 18 ?
ENVautoDetailing.com
SPC rear and the SPC front camber shims, no arms. I wouldn't recommend the shims for the front though, i have the ABS/Slip/VDC lights on all the time. I've tried 10 different combination's of washers for the ABS sensor but still can't get it spaced right.
ok, and the rims come with a +25 offset , you have 10mm spacers all around, but you think they would fit with a 15mm spacer in the rear? i at least want to change something on this setup and not be identical to yours lol
IMO, trial and error, don't get Grant to fit your car. He already did his and you're copying that as it is.
Help only goes so far, there comes a time you need to know what you're talking about.
