19x10 +20 1st gen sedan front.
Old Feb 26, 2011 | 05:28 PM
iiiiiekoiiiii's Avatar
Originally Posted by Gdup35sedan
I'd go 235/35 all around like others have said. You won't need it for clearance in the rear but with a stretched tire you can push the camber out to make it flush. This will save your tires at the sane time. The front will fit fine with a 235/35
Thanx bro,
But I think 235/35 on 10 is way too much stretch... http://tyrestretch.com/10_235_35_R19..._Nexen.jpg.php
I feel like stretching more then needed for the Fit is weak....
Rims I want are linea corseDyna, But i started turning cold towards them, because I feel like their lips arent big enough for 10 inch wheels =X
Old May 21, 2011 | 03:17 PM
I know its been done with 19x10.5 +12 upfront on the sedan.
Thinkin about 20x10 what would be ideal tire size. Kinda wanna run 245/35, Or should I push it with 225/35
Old May 21, 2011 | 04:41 PM
4DGS's Avatar
who?
Old May 21, 2011 | 06:40 PM
DeezNutz lol or w.e. his sn is. I think Cliff was his name.
Clean Custom WHite 1st gen front GA. runnin varrstoens 1.1.2 with 10.5 square set up. I wanted to do it but wouldnt clear brembos so went with 9.5 +3 front now.
Now I found my new set 20x10 with +20 offset really good lips. just gonna try my luck I guess.
just curious if 245/35 would be too much. Cause I still have to keep the front and rear diameter matchin
Old May 23, 2011 | 02:43 AM
4DGS's Avatar
Oh thought Cliff was on a +22 up front.
You've thrown around too many thoughts in this thread that I don't even know what you're talking about anymore.
Are you thinking of doing 225/40 and 255/35 on 20x10 square?
Old May 23, 2011 | 11:37 AM
Z's G's Avatar
Here is when I ran a 20x10 up front 35 offset on 245 35 20 with no problems.
Old May 29, 2011 | 06:41 PM
Im more then sure when he posted up he listed as 19x10.5 all around +12 front +22 rear.
and thats all I needed to know sir, 20x10 245/35 front. Thank u.
How was the poke, if any? cause im looking to run +20 offset
obender66
18 Inch
Mar 13, 2016 12:20 PM
mryogi
Aug 14, 2015 07:58 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
Soumilg
Jul 18, 2015 12:33 PM
