19x10 +20 1st gen sedan front.
Old Feb 19, 2011 | 11:32 AM
iiiiiekoiiiii's Avatar
Alright guys I've been searchin and searching.
Thinkin about running 19x10 square fit on 4 corners
1st gen sedan on Bc coilovers, with ichiba camber kit.
19x10 +20 245/40/19 will be on 4 corners.
Main concern Will it clear the front suspension, and front fenders, Car will be slammed.
Will the fronts tuck, will I need to run spacers to at least match rear poke...
Thanx in advance...
Old Feb 19, 2011 | 11:36 AM
SDGenius's Avatar
pretty sure there's a dude w/XXR's running 19x10 on all four on here...
Old Feb 19, 2011 | 12:00 PM
I think I know who ur talkin about white sedan? I thought he was on 18s.
Old Feb 19, 2011 | 12:20 PM
STCLAIRWEST's Avatar
You should be good..
Old Feb 19, 2011 | 12:23 PM
SDGenius's Avatar
no, not Grant he's on 18x10 +25. the dude i'm talking about had a black sedan on gold XXR's.
Old Feb 19, 2011 | 03:31 PM
anyone got pix, please post up, I wanna see How aggressive it can look...
Old Feb 25, 2011 | 10:08 PM
no love for 10 fronts?
Old Feb 25, 2011 | 10:18 PM
CandlestickPark's Avatar
ill Sedan
A 19x10 +20 is 1mm less aggressive than a 8.5 +0 which is what I'm running. I believe everything will clear (PM Gdup35Sedan to confirm, he's the expert) but you'll need smaller tires, 245/40 is way too tall. Go with a 235/35, remove the screws on the inside of the fender liner and pinch the fronts flat with a fender finisher. Rears will have to be rolled flat, run about -3.5 to -4 camber.
Old Feb 25, 2011 | 10:41 PM
I think 245/40 will be too tall on 19s diameter:26.7
Im thinkin about going 255/35 on 10s diameter: 26.0
I just hope it doesnt hit the screw u're talkin about. Main reason, I have an X. I HAVE TO keep the dimensions closest possible, If I was to run staggered tires on 10s. 225/40 is a perfect match for 255/35.
My rear fenders been rolled flat, with coils now picked up camber kit too, So im not really scared of fitting the rear.
Any hope on 255/35/19 anyone with experience ? Tryin to learn most I can before I pull the trigger.
Old Feb 25, 2011 | 10:59 PM
Matzo Ball's Avatar
255/35 is way to big up front. Like Marcus said, go 235/35 all around and set your coils to near full stiff.
Old Feb 25, 2011 | 11:08 PM
I'd rather go with 225/40F 255/35R
I HAVE to keep my dimensions closest possible cause of AWD. 235 will be too much stretch for no reason in the back.
I was tuckin 19x10 +30 with 275/35/19 in the back just on Eibach springs with weak drop. So on coils Im sure 10mm more aggressive and down to 255 will be perfectly fine.
Now checkin tires...
How does hankook Ventus V12 evo K110 stretch compared to Falken 452 or nankangs.
Im really trying to avoid nankangs, cause I know they are noisy as hell.
Old Feb 25, 2011 | 11:11 PM
ill Sedan
What other widths do these wheels come in? Can you get then in a 9 up front stagger them and do 225/40, 255/35?
Old Feb 26, 2011 | 09:52 AM
they come 8.5F
They are actually willing to break another set and sell me 4 rears...
8.5 +15offset. Lip is weaksauce, So thinkin about runnin max width all around. 19x10
225 will be a lil too stretched on 10... I think.
I just need to be talked out of 10 in the front I guess. lol
Old Feb 26, 2011 | 04:21 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
I'd go 235/35 all around like others have said. You won't need it for clearance in the rear but with a stretched tire you can push the camber out to make it flush. This will save your tires at the sane time. The front will fit fine with a 235/35
Old Feb 26, 2011 | 04:38 PM
mkvl127's Avatar
what rims r u going with?
