Varrstoen ES1.1.2 on Athens Coupe
Old Mar 10, 2011 | 10:15 PM
  #31
ILL_G's Avatar
darkside what are your wheel specs? also if you don't mind me asking where did you order the wheels from because i don't see a vendor here that sells these?
Old Mar 10, 2011 | 10:19 PM
  #32
1sexyG's Avatar
his wheel specs are:
19x9.5 +12
19x10.5 +12
I know because Im going with the same setup...
I went over to my350z.com bc there is a vendor that sells in there. Thats who Im dealing with...
Old Mar 10, 2011 | 10:36 PM
  #33
1sexyG's Avatar
I just ordered mine... only 1 more set left in those particular specs, he said!
Old Mar 10, 2011 | 10:57 PM
  #34
darksideG35's Avatar
19x9.5/10.5 +12 with 245/35 and 275/35 and yes theres a vendor over on my350z.com in the wheels section that is selling the wheels, hit them up over there
Old Mar 11, 2011 | 12:03 AM
  #35
ILL_G's Avatar
Great thanks for the info. did you have to roll your rear fenders?
Old Mar 11, 2011 | 12:18 AM
  #36
4DGS's Avatar
Guy don't go through vendors.
Contact Rich directly at Varrstoen.
12207 Los Nietos Road Unit C
Santa Fe Springs, CA 90670
T: 562-698-8215
F: 562-698-8216
Business Hours: Monday – Friday 9am – 5pm
Can't believe I just did that because I hate fake wheels. But Rich is a really good dude.
Old Mar 11, 2011 | 09:59 AM
  #37
T: 562-698-8215
F: 562-698-8216
thats who i went through Varrstoen is one of the vendors over on my350z.com but i talked to Navith instead of Rich
Old Mar 11, 2011 | 10:02 AM
  #38
i already had my fenders rolled before i had put the new wheels on. it wouldnt hurt to get yours rolled before you do though, never hurts to have a little bit of extra room just incase
Old Mar 11, 2011 | 09:53 PM
  #39
chatt350gt's Avatar
looks great! what camber settings are you running in those pics?
Old Mar 11, 2011 | 09:54 PM
  #40
-2.5 all the way around.. i have rear camber arms and toe bolts but theyre not installed yet, i didnt see the need to put them in when my rear camber would really only be .2 more and my toe was back within spec
Old Mar 12, 2011 | 10:30 AM
  #41
chatt350gt's Avatar
.2 more with camber arms installed? i thought the adjustment was 4 in either direction?? sorry im confused lol
Old Mar 12, 2011 | 10:55 AM
  #42
ya .2 my camber on the car right now is at -2.5 and i wanted to run -2.3 in the rear but its close enough for me. the camber arms can allow up to 4 degrees of adjustment but i didnt see the need to put them on since i was only wanting to go from -2.5 to -2.3 if i was more than a degree off from where i wanted to be then i would have installed the camber arms
Old Mar 12, 2011 | 11:32 AM
  #43
chatt350gt's Avatar
is there a reason why you only wanted -2.3 camber specifically though? i think oem spec is -1.75
sorry for the questions but im getting the 2.2.2 in +12 and want to get as close to OEM spec as i can with a fender roll without rubbing or wearing tires too fast
Old Mar 12, 2011 | 11:45 AM
  #44
with the width of the wheels and the size of the tires that i chose to run, running a little bit more negative camber than oem spec helps keep the wheels from hitting the fenders. If i were to run closer to the -1.75 or so then my wheels would more than likely rub on the fender even with the rear having a mild roll. As it sits right now, i have maybe a one finger gap between the tire and the inside lip of the rear fender
Old Mar 12, 2011 | 12:06 PM
  #45
chatt350gt's Avatar
hmm thanks..well im planning on going with coilovers and having no finger gap all around...and rolling rears as flat as i can get them...you think it would be smart to run those wheel specs with the 245/35/19 front and 275/35/19 rear and have camber around -2? or should i just go +22?
