Replacement tires for OEM 18s
Old Nov 8, 2004 | 12:12 PM
silver_g35's Avatar
G35ers,
Just wanted to get some feedback from you all regarding replacement tires for the OEM 18s. The only one I could find for the standard configuration (225/45/18 and 245/45/18) is the Yokohama EVS….anybody tried these, if so can you give me some feed back ?
Also, considering going to an (245/40/18 and 255/45/18) since there seems to be much more to choose from in these sizes. Looking at the Yokohama db S2 or Kuhmo AVX all seasons ? Have any of you all tried either of these and if so what can you recommend ?
Any other recommendation besides these would be much appreciated.
Old Nov 8, 2004 | 11:23 PM
Powercat's Avatar
Re: Replacement tires for OEM 18s
I bought a set of Bridgestone Potenza S03s in the stock sizes. They have been free of problems for the first 3K with no sign of uneven wear unlike the original Michelins.
Old Nov 9, 2004 | 12:00 AM
avs007's Avatar
I have the Yokohama AVS db tires on my other car. They are pretty good. Nice and grippy, pretty quiet, and decent snow grip. Nice price too. I got pretty good mileage out of them, considering they are a Z rated tire. I put on about 40,000 miles on them so far, and they look to be good for another 5,000 - 7,000 miles. (I drive pretty spiritedly too)
I looked on TireRack, and noticed that both the Michelin Pilot Sport All Season and the Pirelli P-Zero Nero tires are rated with better Dry/Wet/Snow grip than the Yokohamas. The Michelins are a bit pricey, so I might lean towards the Pirellis... When I bought my rims, the 245/40-18 were on backorder, so I got the Michelin Pilot Sport All Seasons. (Won't arrive until sometime in december tho...)
Old Nov 9, 2004 | 06:41 AM
lowrider's Avatar
You've chosen the correct size tires to replace the stockers. The new setup should give you a little more neutral handling car. IMO, the Dunlop SP9000s offer the best ratio of cost to performance.
Lou
Old Nov 23, 2004 | 10:48 AM
jjellyneck's Avatar
The 9000 is a nice tire, but does not have the performance that you'll get from a PZero Rosso, Falken 451, Goodyear F1 GS-D3, ContiSport contact2, Pirelli Nero, Toyo T1S and a few others. The 9000 is a good tire, but not quite as good as some others. Cost is right up there with the rest of them.
'04 6MT coupe
Old Nov 23, 2004 | 11:09 AM
kenchan's Avatar
I agree. Ive used SP9000's in the past thinking that they
would grip as well as their SP8000's, but they didn't.
The GS-D3's are very good tires for street. Alittle softer
on the sidewalls vs S03's, but wet/dry grip is about
equivalent.. plus they are wide tread with bold shouders
so they are much wider (like S03's Azenis, etc).
2004 G35C 6MT Brilliant Silver
S-Tech front / Pro-kit rear / Stillen Camber Rods / Stillen Rear Swaybar
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
itschuckster
Jul 25, 2015 08:07 AM
