Tein Suspension Question
Old Nov 10, 2004 | 07:26 AM
1BadSkyline's Avatar
Does anyone know if the TEin Flex suspension made for the 2004 G35 coupe will fit on the 2004 Nissan Skyline?
The cars are pretyy mcuh the same expect for a few minor differences.
Old Nov 11, 2004 | 02:11 AM
ZeroGen's Avatar
Omega Enthusiast
Re: Tein Suspension Question
I don't see why the G35C suspension wouldn't fit on the JDM Nissan 350GT considering they're basically the same car but with different badging and opposite steering wheels.
The Flex spring rates for the JDM 350GT are softer than the Flex spring rates for the USDM G35C.
350GT: 560 lbs/inch, front & rear
G35C: 671 lbs/inch, front & rear
04.5 G35C TB/Graphite 6 speed, XM Radio, Premo Package, Navi, OEM Chin Spoiler, Hard wired V1
Old Nov 11, 2004 | 06:15 AM
Thanks for the reply
So with the JDM Nissan softer spring rating and the tein flex basically made for the harder spring rating for te G3, will the ride be bad?
Old Nov 11, 2004 | 10:38 AM
R2 V35's Avatar
I have the Flex on my G...ride is okay...not that bad...
"Is simplicity best or simply the easiest"
Old Nov 14, 2004 | 01:07 PM
ZeroGen's Avatar
Omega Enthusiast
1BadSkyline
Considering the Flex has a stiffer spring rate over stock, it will be slightly stiffer. With the Flex, you can adjust for spring pre-load, height adjustment, and damping so ride comfort can be customized. Keep in mind, the Flex is more perfomance oriented than the CS so if you're looking for better suspension over stock but don't want to sacrifice ride comfort, then go with the CS. For me, I've had aftermarket suspension on my previous car and am willing to sacrifice some comfort for performance. Do more research and find what works for you.
Old Nov 14, 2004 | 09:54 PM
i dont really care too much about ride comfort. I am more into looks. So i can do without the comfort. Just that i will be buying mainly US parts for a japanese car so just inquring
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
DimQ
Aug 14, 2015 02:04 AM
TreeFiddy
Aug 10, 2015 06:50 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
