tire question
tire question
Is it ok to go with a different size tire . Currently im running 245/35/20 in the front and want to know if its ok to go with a 245/30/20 tire . Will it fit any different or any other differences other than the shorter sidewall ? Need answer asap . Thanks
Also im thinking of going with nitto invos or hankook ventus v12 . Any feedback on those ?
Sure you can go with a different tire size. the 245/30/20 will be almost an inch shorter in O.D.
I would stick to the 245/35/20, but the 30 series will work as well if you are lowered a bit.
I have the v12's and like them so far.. they do seem to run small though
I running 20" iforged with 350z htechs . So the 30 would be better ? I dont want to have too much of a gap so im not sure .
Debating on going with new ventus v12 or used pair of MICHELIN PILOT SPORT A/S PLUS with 70% tread left for 240 shipped . Anyone ?
Heres a pic
Heres a pic
Given the pic I would keep the 35 series. 30's would look funny IMO, ESP if you go with the V12's....
That is unless you plan to lower it more.
I have 245/35/19's (25.7") up front and I hate how small they look. I bought coilovers so I can set the ride height to make them look good comared to my rear tires. Hankook v12's. No other complaint about them thus far.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
