Help! Rim Leak!
Help! Rim Leak!
Hello everyone, I have a 20" PIAA Rozza that costs almost $1000 brand new. I recently had a blowout on the interstate and incurred a leak inside of the rim somewhere...the rim is not bent. Instead of buying a new rim, which Sealant would you prefer to stop the leak? I believe the rim is Alloy. I tried a cureable marine epoxy and coated the whole inside of the rim, but doing high-speeds on the road it just fell off and did not stick...any suggestions????
Sounds like you've damaged the bead of the wheel.
Take it to a tire shop. Marine epoxy will only matters worse. You need to pull the tire off and seat it with tire cement.
tire shop will fix it... depending where the leak is at. If it's in the sidewall i believe they can't do much. If there's no bends on the wheels then you're fine... just get the tires fix and you're good.
what he said!!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
