19x9 Front with 19x11 Rear
Old Apr 8, 2011 | 11:07 PM
The-Dream's Avatar
What tire size should I go? I'm definitely going to roll my fenders. I was thinking 255/35/19F with 305/30/19R. Would 305 fit the 11" rear well or would it look funny? Would 295 be a better look? I'm scared the tire will look "popped" out too much with the 305. What do you guys think?
Old Apr 8, 2011 | 11:11 PM
Pepper's Avatar
lowered? if so how much? offsets?
Old Apr 8, 2011 | 11:19 PM
CandlestickPark's Avatar
ill Sedan
Really need to know the offsets to answer this question. Fitting an 11 on a Sedan with a 305 out back though sounds like pulled fender territory. G SEDAN ran 20 x 11 +37 out back with a 295/25 and his fenders were pulled 10mm.
Old Apr 8, 2011 | 11:31 PM
broke_as_ajoke's Avatar
i have 11 in the rear on 20's and i run a 285/30/20.. with no problem better grip
Old Apr 8, 2011 | 11:33 PM
ill Sedan
OP are you looking to fit these on your coupe or sedan, big difference.
Old Apr 9, 2011 | 03:20 PM
The-Dream's Avatar
Sorry I should of said which car, I'm going to be fitting it on my coupe. I've decided to leave my sedan stock.
Old Apr 9, 2011 | 04:09 PM
Sylvan lake V35's Avatar
2" stager FTL go 20x10 20x11. if you want normal fitting tires go 285-295mm 305 wont really look overly fat but 11" is about the correct size for a 305mm.
Old Apr 9, 2011 | 05:30 PM
bro this is a 285/30/20.. this b4 i dropped it
Old Apr 10, 2011 | 11:29 AM
ILoveMyGee's Avatar
damn 305 is wide
Old Apr 10, 2011 | 01:34 PM
The-Dream's Avatar
I'm going to drop my ride about 1".
I'm scared 10" in the front is too wide and I won't be able to turn. I'm also going to go with 19s, I have 20s now and I don't like them.
Old Apr 10, 2011 | 11:55 PM
I have 10.5 in the front and theshaddix has 11" on the front of his Z so 10" would fit fine. I would be worried about oversteer with that large of stager I guess if you don't ever drive the car hard it might not be an issue.
Th611
Oct 27, 2015 03:48 PM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
