Questions about offset on Varrstoen wheels
Old Apr 9, 2011 | 04:38 PM
erm007's Avatar
Okay, I know by running 19" wheels with a +22 offset with 9.5 front 10.5 rear will be the easiest route when considering having to roll fenders and adjust camber. However I've been thinking about going with 18" wheels 9.5 front 10.5 rear instead of 19". I was wondering if anyone knows which offset would be the best to go with in these with the least amount of modifications. In otherwords, which offset for 18's is the equivalent to the 19" +22 offset or is + 22 the same in 18's? I'm kind of lost when it comes to the difference concerning wheel diameter and offset and whether a large wheel diameter changes the offset. I'm not looking for an extreme offset.
Offsets available in 18" 9.5f and 10.5r in this wheel are
+30
+22
+15
+0
Old Apr 9, 2011 | 04:49 PM
chatt350gt's Avatar
offset is just how tucked or how far the wheel is from the wheel hub mounting surface. going with the 18 inch +22 or the 19 inch +22 will still have the same effect as to where the wheel sits..the wheel is just smaller..if you dont want to do fender work go with +22 depending on how low you are..but if i went with the 18 inch i would get the +15 and do a mild roll.
Old Apr 9, 2011 | 05:13 PM
4D05G35's Avatar
Like ^ said. Offset is just the distance measured from the wheel center to the mounting pad of the wheel.
Positive offset means the mounting pad is offset closer to the face of the wheel, and negative offset means the mounting pad is offset closer to the inner lip of the rim.
Wheel diameter plays no role.
Old Apr 9, 2011 | 05:40 PM
erm007's Avatar
Thanks for the info. I understand offest, just didn't know whether wheel diameter had a different effect on offset such as if a 18x10.5 inch wheel with a +22 offset is more aggresive than a 19x10.5 wheel with +22. But it seems diameter has makes no difference. Now if I have a 1 to 1.5 inch gap between wheel and fender, could I run a +15 or even a +12 without rolling the fenders or adjusting the camber?
Old Apr 9, 2011 | 07:11 PM
chatt350gt's Avatar
From everyones experience a +15 and +12 will need atleast a mild roll..ill be rolling mine flat..that's if you run the normal 245 275 setup which you should since stretched tires on a +12 don't look that good..and also depends on how low you are
Old Apr 9, 2011 | 07:18 PM
4D05G35's Avatar
18", 19", 15" it's all the same. They will fit the same as far as offset goes.
What is your suspension set-up? Is it stock?
Wheels of the same offset, diameter, and width will fit differently on a lowered car vs stock height car.
What gap are you measuring? What are your current wheel specs?
Old Apr 9, 2011 | 08:27 PM
Sylvan lake V35's Avatar
Anything lower than a +22 will require rolling the fenders unless you stretch the tires but 245F and275-285mm rears will require a roll on a +12 or +15.
Old Apr 11, 2011 | 03:06 PM
erm007's Avatar
My suspension is stock for right now. I'm looking at lowering it just a little. I don't want it slammed, been there done that before and didn't really like it. How about if you get +22 and put 5mm spacers on it and bring it to +17. I saw where someone on here did it and it brought the wheels out flush, but didn't mention whether or not they had to roll the fenders or not.
Old Apr 11, 2011 | 03:52 PM
monkeyballzjr's Avatar
I'm looking at the same setup as well but I don't really want spacers. Guess I might have to go with the +12. I thought I saw someone on facebook, it might've been on the Varrstoen page that said he was running +12 and didn't have his fenders rolled, not sure how accurate that is though.
Old Apr 11, 2011 | 04:15 PM
chatt350gt's Avatar
I've only seen 1 person run +12 without a fender roll but they did need to...running a 275 or 285 rear will need a fender roll..especially if u want camber settings fixed
Old Apr 11, 2011 | 06:04 PM
erm007's Avatar
I've notice ya'll have all mentioned the rear fenders having to be rolled with +12, and anything 275 or 285. Do the front fenders not have to be rolled at all then with +12?
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Soumilg
Jul 18, 2015 12:33 PM
