245-40-18s on front (coupe)?
Old Nov 16, 2004 | 12:40 AM
fldrummer's Avatar
Has anyone put this size tire on their coupe front end? 'Just wondering if there is anything negative (i.e. bad fit on the rims, wheel well rubbing, etc.) that could happen by going to a slightly wider front tire (as opposed to stock 225-45-18s), besides minimal speedometer error. On that note, does anyone know whether the speedometer reads off the front or rear wheels? Thanks.
2004 6MT (Silver/Willow), premium & aero packages
My old ride (I still miss her; put a lot of pride and joy into it): http://www.n-body.net/registry/john95ga/
Old Nov 16, 2004 | 05:11 PM
ifleyelearz's Avatar
Re: 245-40-18s on front (coupe)?
I was just at the dealership today to ask pretty much the same question. They told me that they had to be 225s on the front because they will rub. I'm not sure if thats just 'recommended' or if it would actually be ok. I am wondering the same thing though because I want to put snow tires on all 4 that are 245/45/R18 (same as the back).
Old Nov 16, 2004 | 07:04 PM
avs007's Avatar
Your dealer is probably full of it. There are tons of people running 245/40-18 on the front. Myself included (once my rims arrive)...
Also, your speedometer will not be off. The car is RWD, so the speedometer is associated with the back wheels, not the front... (Speedos are usually connected to the tranny)
Old Nov 16, 2004 | 08:49 PM
fldrummer's Avatar
Thanks, guys. Please let me know if the dealer IS full of BS about the rubbing when you get your new tires on... If anyone else can speak from experience, please share it.
Old Nov 17, 2004 | 02:52 AM
Renesis's Avatar
Um........ considering sedan owners can put 245/40 R18 in the front as well, i don't see why the coupe can't do it. I would say the dealer is full of it.
Old Nov 17, 2004 | 04:00 AM
borahatch's Avatar
you should be ok with a 245/40 18 up front... i have a 245/35 20 on the front of my coupe with no rubbing at all.
Old Nov 19, 2004 | 06:28 PM
Brando's Avatar
I think he is talking about putting them on the stock 18's......I don't know if the recommend that wide on a stock wheel?? A good tire / wheel comppany should be able to tell you.
But I have a set of Volks - 9" w in front with the 245/40's and there is plenty of room.
"I like you.....You remind me of myself when I was young and foolish"
Old Nov 19, 2004 | 09:48 PM
03G35Black's Avatar
i have 245/40/18 on the front and 255/45/18 on the rear. it rides great. rides much better than the stock setup. even my dealer thinks so.
Old Nov 20, 2004 | 11:49 AM
jjellyneck's Avatar
03G35Black,
You're saying that the ride is better...how about the overall handling? Which tire brand and model are you running in that size?
'04 6MT coupe
Old Nov 22, 2004 | 09:41 PM
Gruen's Avatar
The dealer is full of it! I have 245/40/18's on the fronts in my coupe 6sp and there is no rubbing, even when the wheel is cranked all the way over. I tested that as soon as I had them installed. I did notice that when I was looking for 255/45/18's for the rear, some manufacturers had specs which listed 8" rims as the bottom end of the rim size and other did not! All tires will have the recommended rim size in the specs, you just have to look for it. I wouldn't try and squeeze a tire on the 8" stock rims that is listed at 8.5-10" rim width. Just make sure the manufacturer that you pick for the 255 rears has 8" listed at the minimum spec range. I have a set of Kuhmo all seasons that fit great. Fronts - 245/40/18 Rears - 255/45/18. The back end looks better with the 255's on stock rims. I'm very happy with them and you can be confident that it WILL work.
Last thing - The Diameter of the tires are almost identical to stock. This is key, if you match the diameter then you don't have to worry about messing up the VDC or changes in your speedo. The diameter of the 245/40/18 fronts is only off by .1 inches in the front compared to the stock 225/45/18. the 40 is a percentage of the 245 width so the wider tire at a 40 profile is about the same as the 225 wide tire are a 45 profile, get it. Just check the diamerter on the stock tires, and the diameter on the tires you want and make sure they match. Diameters will vary from manufacturer to manufacturer so look at it!
<P ID="edit"><FONT class="small"><EM>Edited by Gruen on 11/22/04 06:48 PM.</EM></FONT></P>
Old Nov 22, 2004 | 09:43 PM
Gruen's Avatar
I can take a picture of them if you want to see the fronts and the rears at 245/40/18 & 255/45/18 on stock rims. I'll post it in this thread if you guys want to see what it looks like.
Old Nov 23, 2004 | 09:56 AM
jjellyneck's Avatar
Yes. Please post some photos.
'04 6MT coupe
Old Nov 23, 2004 | 10:42 AM
kenchan's Avatar
For those that are running the 245/40/18's up front on stock
wheels, do you get any tramlining from grooves on the
road? That was my main concern.
Im thinking about doing the Ziex512's in those sizes
after the butt-ugly Pilots wear out...
2004 G35C 6MT Brilliant Silver
S-Tech front / Pro-kit rear / Stillen Camber Rods / Stillen Rear Swaybar
newg37
Jul 26, 2015 09:32 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
djreinx
Jul 13, 2015 05:04 PM
