Noise w/Kinetix Front Camber A-arms
Old Nov 16, 2004 | 01:30 PM
G35pm's Avatar
Just installed the Kinetix Front Camber A-Arms and they are squeaking when going over bumps at slow speeds (< 25mph). Anyone have any solutions for this? Types of grease(brand)? Thanks.
Old Nov 16, 2004 | 02:31 PM
nismoGcoupe's Avatar
Re: Noise w/Kinetix Front Camber A-arms
Yes, I would like to know too before I get mine installed.
G35pm did you get an alignment yet if so was the front arms difficult to adjust???
Old Nov 16, 2004 | 04:29 PM
G35pm's Avatar
Alignment tomorrow. Just looking at how they were designed, adjustment isn't easy (for a big change, you would have to unbolt part of the arm). My installer set them so that alignment could be set back to nominal w/out having to take out or unbolt the A-Arm.
Old Nov 16, 2004 | 04:39 PM
G35pm's Avatar
Response from Kinetix:
You can liberally grease the bushings and the aluminum sleeve that runs through the bushings. Also check for clearance between the ball joint and the plastic liner at the top of the wheel well. The ball joint changes positions as the wheel is turned so look for clearance in the entire area.
Also it is very likely the squeeking will go away shortly when they break in.
Old Nov 16, 2004 | 10:32 PM
g35pm thanks, please post your results from the alignment,
did you install the rear camber & traction arms also???
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
rping
Jul 26, 2015 09:53 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
