wheel fitment problems
Old Apr 18, 2011 | 01:00 AM
bakasam's Avatar
My wheels are SSR SP1 on 2003 g35 sedan
19 x 9.5 +43
19 x 10 +37
My rears are clearing fine, but my front wheel is sitting right on top of the inner arm. Im the third owner of them and i believe the first owner has a g37 sedan and they fit fine. Hoping that a 5mm will help me with my problem. Could it be another problem..currently on stock a-arms..
Is there anyone with a similar setup that could help me out plz :]
Old Apr 18, 2011 | 01:02 AM
kennymo's Avatar
im going to guess that you have a coupe. and if you do....that high of a offset is WAAAYYYY to high for a coupe. you need like a 1.5 inch spacer
Old Apr 18, 2011 | 01:12 AM
bakasam's Avatar
woops sorry, im a 2003 sedan
Old Apr 18, 2011 | 01:14 AM
kennymo's Avatar
oh ok then thats a little better. i would get a 15mm spacer then
Old Apr 18, 2011 | 01:17 AM
bakasam's Avatar
the only is about a 15mm spacer is that my wheel arent made to fit bolt on spacers, will need to get a set with extended studs..not looking forward to replacing studs. You think a 5mm will do the trick, making it +38 up front?
MsFitFern
Aug 9, 2015 02:58 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
atk08
Jul 30, 2015 03:12 PM
sailfish250
Jul 30, 2015 11:39 AM
Soumilg
Jul 18, 2015 12:33 PM
