Need some advice on bolt pattern. Please help
Old Apr 27, 2011 | 11:09 PM
louiss1tires's Avatar
Hi all,
So i'm still a newb here. I know that the bolt pattern for the 2004 g35 is 114mm. However, I really liked these rims that I found, everything fits except for the bolt pattern. The bolt pattern on those rims are 120mm. Is it possible for it to fit? I did some research and some people say that you can, but have to buy the adjuster. Some people said impossible. Is it possible??
Thank you all for you replies.
Old Apr 28, 2011 | 03:03 AM
4D05G35's Avatar
You can buy an adapter, but you have to factor that width into the equation. The adapters ive seen usually are about 30mm ( or just over an inch). If you can fit that and the wheels then you'll be fine.
Old Apr 28, 2011 | 03:54 AM
4DGS's Avatar
What wheels are they, I'll bet I can find you wheels that look the same but in 5x114.3
Old Apr 28, 2011 | 10:45 AM
4D05G35's Avatar
^ thats the best option.
Old Apr 28, 2011 | 01:53 PM
The wheels are Lexani LX-14. Offsets are front: 18x8x30. Rear: 18x9x40
Lugs are 5x120
What do you think??
Old Apr 28, 2011 | 02:18 PM
Deezflip's Avatar
^the wheels are not my cup of tea, especially since:
1) They're 18's
2) you have to go out and get wheel adapters/spacers for it.
With AT LEAST $150 a pair for those wheel adapters, you'll spend $300 dollars to make it fit. Just my 2cents...but nevertheless it's not impossible. Google 114.3 to 120 adapters.
Old Apr 28, 2011 | 04:18 PM
1) They're 18's
Thanks a lot for your help!
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
