Love my G, but hate my yearly tires...
Old May 3, 2011 | 02:51 PM
herrschaft's Avatar
^You can, I ran that setup for a while.
Old May 3, 2011 | 02:59 PM
Neal376's Avatar
Originally Posted by Manny2ksi
any suggestions?
obviously with 24,000 miles a year im a DAILY driver so im looking for that more that sporty or race quality.
thanks!
the negative camber lets the car carve into the corners. removing the camber would technically reduce performance but you probably would not notice it in day to day driving. there really is no major difference between the camber kits except price and brand name. they all do the same thing
also. if tire wear is your biggest concern, get tires with the highest UTQG, i.e. around 500. OEM tires, and the sterotypical "high performance tires" have really low ratings around 150-200. They stick more, but they also wear out much quicker. getting a tire with high UTQG makes a big difference
also sounds like your rear tires were overinflated. "center wear" is not consistent with neg camber wear (its suggestive of overinflated tires). inner shoulder wear is suggestive of neg camber wear.
Old May 3, 2011 | 03:55 PM
Manny2ksi's Avatar
so if i decided to go with one tire what should it be.....
245/40/19
Old May 3, 2011 | 04:26 PM
w4kj4k's Avatar
Do you check the sheets to see what you're specs are after they align it? But overall 24k a year is REALLY good, i remember when i got like 4k on a set of rears... there went $400
Old May 4, 2011 | 05:31 AM
Blue Dream's Avatar
I drove ttrank's car solo
That's so incorrect it hurts my head to read it. Talking about front kits, the only 2 available on the market that will give you any significant positive camber adjustment are the SPC and the SPL. The rest out there don't have the capability. For the rears, the Ichibas are well known for bushing failure and mine have suffered the same fate. Long story short all camber kits are NOT the same so if you go that route OP please do your research before you buy anything.
Old May 5, 2011 | 09:48 AM
Manny2ksi's Avatar
Thx Blue Dream.... ive been researching up the wazooo....
i think im going to skip the $500 camber kit and instead of buying the directional Nankangs again im going to go with the Conti's DWS and then rotate them like every oil change and get a Dealership alingment since im on the 350z H's.....
anyone think this is an ok plan or have any other suggestions?
also, would now be an ok time to add spacers?
Old May 5, 2011 | 10:29 AM
Neal376's Avatar
sorry, I thought we were only talking about the difference between SPC and SPL
Old May 5, 2011 | 10:58 AM
herrschaft's Avatar
Depending on which ones you get you can add spacers at any time. If you get the ones with the built-in studs, its as easy as changing a tire.
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
Gip
Aug 24, 2015 05:31 PM
