Love my G, but hate my yearly tires...
I have a 2006 G35 Coupe (STS). I have 115,000 so im runnning about 24,000 miles a year. i have a slight drop with the 350Z Teins.
ive replaced my tires ever single year.
i am about to get my 5th set of tires. Currently i have the 35 series setup.
the last two times i installed my tires i had a (top of the line, in terms of shops) Alignment done where the guy told me i dont need a camber kit that he would get me in specs.
on this setup, the rears are going bald in the middle and the fronts are bald on the inner tread.
should i go ahead and get the CAMBER kit?
should i buy better tires?
because i go thru so many tires, the last 3 sets have been the NANKANG NS-ii
thanks for any and all help!
obviously with 24,000 miles a year im a DAILY driver so im looking for that more that sporty or race quality.
thanks!
What tire pressure are you running, should not be more than 37 PSI! Tires don't wear out in the center unless you're running to much pressure. If you're wearing out the inside quarters up front you may also have other suspension issues since you have high mileage on your G. The camber kit will help but you need to make sure you don't have other issues.
Gary
Gary
Where are you getting your alignment I tried several shops for an alignment and it seems no one could align the car right. I kept going through tires until I went to the dealer for an alignment, and I had no more wear problems since, and I notice my dealer here in Ga was only five dollars more than the other shops so for now on I'll get my alignment done there. My car is a 04 sedan sport model with Tein H techs.
Gary
Gary
i have tokico Blues and tein H's and i think the suspension is ok.
this is the first set that went bald in the middle. usually it is always the inner tread.
so if i get a good camber kit and some better tires as far as TREADWARE goes that will make a difference?
most ppl say that all G's & z's have this issues no matter what.
Also get tires that are asymmetrical so you can swap at least the fronts side to side.
what tires have you been buying? The oem RE050s are good peformers but have terrible UTOG
24k is pretty good for tires, the most you going to get is close to 30k but I doubt you'll go more, even with a camber kit.
What you can do is get a symmetrical tread tires and flip them half way though the life of a tire.
As far as the rear, your tire wear suggests high air pressure.
