running squared setup on a coupe?
May 12, 2011 | 07:58 PM
hey im about to buy a used set of wheels and they are 19x9.5 on 235x35 tires all around im wondering are there any risk in running a square set up on my 05 coupe? im on stock 19s right now running staggered. and how would they look if thanks.
Reply 0
May 12, 2011 | 08:01 PM
..No..
Reply 0
May 12, 2011 | 08:02 PM
so it would be the same? like does anything change ? pros and cons?
Reply 0
May 12, 2011 | 08:07 PM
It will practically be the same. As long as the front and rear tires are roughly the same height, which they are, you will not experience any VDC issues.
Reply 0
May 12, 2011 | 08:22 PM
^^^what he said.
Reply 0
May 12, 2011 | 08:55 PM
i thought the car came from the factory staggered so it must be some reason it came like that.. So it has to have some effect somewhere if he doesn't have a staggered setup.. thats my 2 cent
Reply 0
May 14, 2011 | 01:18 PM
I run 265/35/19 all around and the car is fine. You will hardly notice any difference - though at the absolute limits, you will also reduce understeer.
Reply 0
May 14, 2011 | 03:58 PM
Search... this has been covered plenty of times.
Reply 0
