Should i go with 10mm or 15mm spacers
Old May 17, 2011 | 07:58 PM
jazzy's Avatar
post some pics of your G
Old May 17, 2011 | 08:04 PM
Adil_G35's Avatar
haha as soon as i buy some wheels. im stuck on these oem 18's. I had my mind set on the staggered 526....but we all know the story...blah blah blah
Old May 17, 2011 | 08:13 PM
jazzy's Avatar
Concept One RS8 Wheels and Varrstoen ES 1.1.2 are nice looking rims for reasonable price
Old May 17, 2011 | 08:19 PM
Adil_G35's Avatar
Define reasonable? 1000?
Old May 17, 2011 | 08:23 PM
jazzy's Avatar
1000 to 1500 also Axis Penta are nice too
Old May 17, 2011 | 08:34 PM
qbanboy's Avatar
Originally Posted by jazzy
I recently got my front wheels 20x9 +15 on 245/35/20 i can put one finger between the fender and tire fenders are not rolled yet and car is lowerd on 350z Eibach sportline springs should i go with 10mm or 15mm spacer and i will be rolling the fenders soon
[IMG][/IMG]
I saw the car from the side picture, my personal suggestion is get an alignment and them go from there....
To see how far you want it just measure from the outside of the rim to where you actually want it....but if i was you i will just do the alignment it will probably look more flush than now....
My question is Do you have a camber kit in the front? if so do what i told you and it will get you set.....
what i see in the pic is that you lower your car, so your wheels are actually a little tuck outside to the bottom of the wheel...once you do this will give you more straight angle than the one you have now.....
Old May 17, 2011 | 08:45 PM
qbanboy's Avatar
just checked 15mm would fit its about the same width as my finger
10mm is a 3/8 inch that's really close to a finger width depends how fat you are LMAO...20mm is almost an inch is to much and 15mm is 5/8 inch more than 1/2 inch I will go with 10mm spacers if you need it....but i think you will rub...dont know!!!
Old May 17, 2011 | 09:00 PM
jazzy's Avatar
i guess i have fat fingers lol with the 10mm how hard is it to put the extended bolts
Old May 17, 2011 | 09:10 PM
qbanboy's Avatar
i dont know bro but i think you may need to get longer struts...my guess!!!
Old May 17, 2011 | 10:05 PM
Evolved8's Avatar
Hmm I'm still not feeling the whole convexness of the fronts.
And is it just me or does the side profile of the rim look like the lip(where the rim meets the tire) is just too big?
Does that make sense?
Old May 17, 2011 | 10:10 PM
qbanboy's Avatar
no bro these wheels have a 2.5 lip
Old May 17, 2011 | 10:12 PM
jazzy's Avatar
its actually 3.25"
Old May 17, 2011 | 10:19 PM
4D05G35's Avatar
I dont think its too hard, but more time consuming than anything.
someone correct me if I am wrong, but I believe that you can tap them out (more force then a tap). Then using some washers and a lug nut to pull the new ones through into place. As you tighten the lug nut it pull the stud into the hub. I've never dont it so I might be off there, thats just what I heard.
I just dont like the idea of longer studs because I swap wheels in the winter. I guess I could use open ended lug nuts, but bolting on some spacers with built in studs is so nice...Easy on, easy off back to stock. Plus they cost about the same.
Old May 17, 2011 | 10:22 PM
4D05G35's Avatar
its actually 3.25"
Nice, any idea what the rear lip will be. The lip on my rear wheel is 4.25" and I love it, thats what sold me on the wheels.
Old May 17, 2011 | 10:25 PM
  #30
jazzy's Avatar
well you will love these more they are 5.25"
