Need Offset help TONIGHT (ordering tommorow!!)
Old Nov 24, 2004 | 12:48 AM
Raznips's Avatar
I'm ordering a set of 18x9 and 18x10 in rear speed star racing proffessor sp1's tommorow. I need to know exact sizes to ask for. I want the best offset that just barely clears my brakes (never upgrading brembo calipers), but yields the largest lip. I'm no expert on wheels, but im guessing that whatever wheels clear my brakes by the least amount, will give me the biggest lip. This is my last chance to change my mind on sizes. I was going with 19's but decided on 18's because of weight difference and because i decided i like the look of 18's slammed more than i like 19's sitting low. (i saw a similar drop on stock 18's and on 19inch gt-c's and thot the 18's looked a lot more hardcore dropped. Any comments/questions/ advice would be GREATLY appreciated. These are getting ordered TOMMOROW like i said....
anywhere that you think i should order these besides www.tirerack.com ? They will be here in march if i order them, which is the lag time anywhere (i checked around for these in stock and couldnt find them anywhere ).
2004 Black on Black g coupe 6spd.... aluminum pedals, clear corners, z tube, and pop charger with 20% madico tint
Houston Texas
Old Nov 24, 2004 | 05:58 AM
neffster's Avatar
Re: Need Offset help TONIGHT (ordering tommorow!!)
I *think* it depends on the wheel. I have +25 offsets front and rear on my PIAA's, but I believe that each spoke can be slightly different. The offset only measures the distance from the back of the hub to the back of the rim (if I'm not mistaken) BUT it is independent of the spoke design. Usually the spokes are what you're trying to have clear the calipers, so maybe just speak with the manufacturer and see what they recommend.
Old Nov 24, 2004 | 12:42 PM
kenchan's Avatar
Offset is the distance from the center of the wheel to
the back of the hub.
So for instance, +25mm will sit closer to the fender vs
+37mm.
I would probably choose something in this range:
+24 to +32 front
+27 to +37 rear
2004 G35C 6MT Brilliant Silver
S-Tech front / Pro-kit rear / Stillen Camber Rods / Stillen Rear Swaybar
Old Nov 24, 2004 | 01:25 PM
Raznips's Avatar
i know what the offsets i would want for 19's are.... how much differnet would i need to get offsets for the 18's
Houston Texas
Old Nov 24, 2004 | 03:16 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Raz
Wheel DIA has nothing to do with offset.
the same offset applies to both.
<font color=blue>04 Silverstone G35, 5AT, Prem, Aero
ES100 225/45-18 front 245/40-18 rear
HKS & Y-pipe, Z-tube, Eibach, 35%Tints</font color=blue>
Old Nov 24, 2004 | 05:21 PM
kenchan's Avatar
Who said anything about only applies to 19's?
You can use those offsets 18 or 19 or even 20.
Picture Share
Feb 4, 2018 12:41 PM
TurTLe*
Sep 29, 2015 01:43 PM
