Question on modifying wheels/tires on G35 Sedan
Old Apr 21, 2003 | 07:30 PM
lip11's Avatar
I'm a little disappointed with the few tires available in the stock 215/55 R17 size, so I'm thinking of buying new 18x8" rims so that I can put 225/45 R18 or 235/45 R18 tires on them. Has anyone done this? Any advice? I don't want to degrade anything, like the VDC, speedometer accuracy, handling, etc...
Thanks,
John
Old Apr 21, 2003 | 08:11 PM
ryoken's Avatar
Re: Question on modifying wheels/tires on G35 Sedan
Hey.. this question looks familiar. I just saw it in the Sedan forum. [img]/w3timages/icons/smile.gif[/img]
VDC is okay as long as you put 4 of the same size tires on all four corners, don't stagger the tires on the sedan (like they do on the coupe).
For speedometer/odometer, pay attention to the tire diameter, and keep it as close as possible to the stock size. 235/50R17 and 235/45R18 are just about perfect. 225/55R17 and 225/45R18 are not as close, but still within allowable tolerances.
Infiniti officially says 225 is the widest you should go on the front. I figure 235 is still okay. 245 is pushing it, but I see some others are doing that -- don't know what would happen if you hit a hard bump with the steering wheel fully turned with a tire that wide, though.
If you scan through the old topics here, you'll see what many others are doing.
Old Apr 22, 2003 | 12:10 PM
lip11's Avatar
Thanks for your feedback! I think I'll go with the 235/45 R18s...
Old Apr 22, 2003 | 07:33 PM
ryoken's Avatar
The only catch with 235/45R18, is that the tire selection is as limited as (if not worse) than the stock 215/55R17. Tire Rack recommends 235/50R17 for 17" rims, and 225/45R18 for 18" rims for our sedans. There are plenty of good performance tire choices available in these sizes.
Jusseth
Sep 13, 2020 12:25 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
newbdriver01
Jul 16, 2015 11:35 AM
mushu
Jul 15, 2015 03:55 PM
