255/30 or 235/35?
Old Sep 8, 2011 | 01:32 PM
sroks5's Avatar
255/30 or 235/35?
I am currently at -4 degrees of camber in the rear running 245/35/30 nexen tires.
I want to put my camber at about -2 degrees. Which tire size should I run?
I am currently rubbing in the rear when I have a full car. It is rubbing on the sidewalls of the tire.
thanks for the input
Old Sep 8, 2011 | 04:07 PM
4D05G35's Avatar
If you are rubbing on the sidewall and you want to run less camber a wider tire will only make that worse.
Old Sep 8, 2011 | 06:15 PM
4DGS's Avatar
You mention the widths and offsets.
Current info is useless.
Old Sep 8, 2011 | 06:46 PM
sroks5's Avatar
i am running 20x10.5 0 offset in the rear
Old Sep 8, 2011 | 10:52 PM
Frankieg35's Avatar
245/35 would be ideal..
AidanP
Archived Sales
Apr 8, 2010 12:22 PM
Captain Supreme Sausage
Feb 26, 2010 02:24 PM
nevdull
Nov 8, 2008 12:27 PM
gabezor
Jan 4, 2008 04:35 AM
