Front Hub Assembly for 2003 G35 Coupe
Old Sep 10, 2011 | 05:06 PM
jabca's Avatar
Hey guys,
I need to replace a front hub assembly on my non-Brembo 2003 G35 Coupe. Looking over the forum it seems the TIMKEN HA590027 should do the trick. When I went onto rockauto.com I found that part, but I also see the TIMKEN Part # HA590127, which is for the 2003 G35 and "Exc. Stability Control".
I'm unaware of any G35 without stability control (VDC), so I should stick with the TIMKEN HA590027, right?
Thanks,
Jon
Old Sep 12, 2011 | 11:00 AM
jabca's Avatar
Here is the official response from Timken when I posed this question:
When we originally sourced this part from the Infiniti dealer, there was a unique OEM part number, which has recently been superseded to the same manufacturer part number for both parts. HA590027 will remain the active part for the G35, and any HA590127 in stock can be relabeled to the HA590027. The Catalog will be updated to match the supplier information. Both HUBS have the encoder seal used for ABS and Traction Control.
HA590027 AND HA590127 REF SAME OE NUMBER 40202AL56C
TWASkyliner
Feb 8, 2020 08:00 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
papo020
Jul 17, 2015 10:30 PM
Chattzx
Jul 17, 2015 11:23 AM
