Who Has VarrsToen Wheels on their Cars?
What suspension you running in this?
yusoslo: You definitely sold me on these rims with that stance... I'm looking for the 113's, and hopefully achieving something close to you that may be a little less aggressive... Fenders pulled? All four corners rolled flat? Any details on your suspension/setup/camber, kit etc? Thanks
Aircraft stripper. Then use wd-40 as your wet sand lubricant. 800-1000-1500-2000 then 0000 steel wool then jewelers rouge on a drill powered polishing pad, then mothers polish, then 3 coats of optibond.
It is a mirror shine, the first set of pics where just a 2000 and polish test spot. The most recent is 3-4 hours per rim, finger bleeding process. The hardes part is sanding out the grooves in the machined lip so it's flat.
You and me both, Setko's-G35. I'm sure you already know, but only the hyper black 1.1.3's are up for preorder for the 1st shipment. But when the silvers come in, im gonna be doing the same thing as you and yusoslo if another rim doesnt come in and catch my eye--- I need rims like yesterday!
What color are you painting the face?
