what front fender mod for aggressive offset?
Old Oct 17, 2011 | 11:18 PM
JC-RH's Avatar
i'm finally getting my wheels/tires installed on my g35 coupe this wednesday. here are the specs:
front 20x9.5 -7 offset 225/35/20 Hankook V12
rear 20x10.5 0 offset 245/35/20 Hankook V12
I'm planning to sit right at the top of the tire with a -1.8ish camber all around. I currently have my rears semi rolled, so I'm hoping they wont be a problem. I'm more worried about my front. I hear some people have removed or grinded down one of the bolts. What exactly do people do with their front when they are low and running an aggressive setup?
If anyone has pics to illustrate, that would be awesome.
Old Oct 17, 2011 | 11:22 PM
CandlestickPark's Avatar
ill Sedan
People who run aggressive offsets up front typically do the following (in this order):
1. Remove the screws that hold your fender liner in place (unless you are dumped they will stay in place just fine)
2. Clean the inside of your fender make sure there isn't any pieces of debris in there prior to performing step 3.
3. Use a heat gun and fender finisher to pinch your fenders flat.
I'm not an expert on Coupe fitment to tell you whether you'll be good with -1.8 camber given those widths/offsets or not. I'm sure someone else will chime in.
Old Oct 17, 2011 | 11:24 PM
JC-RH's Avatar
what's a fender finisher? are you referring to a fender rolling tool?
Gdup35sedan's Avatar
ENVautoDetailing.com
You're going to need more than -1.8* camber up front for that setup. More like -3.0* or more...
Same on the rear, you'll need around -2.5*
Old Oct 17, 2011 | 11:27 PM
ill Sedan
Eastwood fender finisher, its different than a fender rolling tool.
Old Oct 17, 2011 | 11:30 PM
Deemo's Avatar
I was running 19x9.5 -8 on a 225/35/19 with -2 camber and didn't do any modifications to the fender. Didn't even have to remove the screws
Old Oct 17, 2011 | 11:32 PM
Deemo's Avatar
I was tucking a little bit of tire.. My fender to ground height was 24.5"
ill Sedan
^He might have to because he'll be running a taller tire up front than you had. Like you noted, ride height will play into it as well.
Old Oct 17, 2011 | 11:35 PM
+1
225/35/20 is an inch taller than a 225/35/19
Old Oct 17, 2011 | 11:37 PM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
This is the troof.
-2 offset all around, 9.5 and 10.5 widths front and rear. -2.5 degrees of camber all around. When I had the 0 offset all around, it was -1.8 in the front and -2.2 in the back.
Flat roll in the rear. Removed fender clips in the front. Slight fender pull in the front.
Old Oct 17, 2011 | 11:41 PM
Deemo's Avatar
True. I would just remove the screws and go from there.
Old Oct 17, 2011 | 11:55 PM
JC-RH's Avatar
hmmm...this is good info for when wednesday rolls around. i can't wait!!
Old Oct 18, 2011 | 12:07 AM
sdz33's Avatar
You definitely want to remove the fender liner screws and roll/pinch your front fenders flat!... I didn't use a finisher or roller, I just heated up my fenders and banged them flat with a hammer.... DO NOT try my method unless you are experienced with a body hammer!
I am also running a 20x8.5 +15 with a 225/35/20... I was semi-dumped and it rubbed prior to those simple fender mods... I reccomend you do this before getting your new wheels and tires installed... It will save you time and maybe a few headaches...
Old Oct 18, 2011 | 07:59 PM
JC-RH's Avatar
tomorrow's the big day. any other suggestions?
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
st33zygill
Jul 29, 2015 10:05 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
bickfordbft
Jul 20, 2015 07:57 PM
Soumilg
Jul 18, 2015 12:33 PM
