odd rubbing in front (only one side)
Old Oct 26, 2011 | 06:45 PM
JC-RH's Avatar
I'm rubbing my front passenger side bumper bracket on big dips and bumps, but my front driver side is perfect. I'm currently running 20x9.5 wheels with a -7 offset wrapped in Hankook 225/35/20. Like I said, left is perfect, but right side rubs on the bumper bracket by the sidemarker. I got an alignment a couple weeks ago, and I'm at 0 toe and about -1.6 camber on the side that rubs, and about -1.1 on the side that clears. I'm running on HKS coils, and I have it set right above the tire. I also recently got the front rolled and pulled, but that doesn't really affect the bumper bracket placement.
I trimmed it down some, but it's still rubbing. Is it safe to just cut it off completly? What other suggestions do you have?
Old Oct 26, 2011 | 09:10 PM
JC-RH's Avatar
Old Oct 26, 2011 | 09:33 PM
B_Lam's Avatar
I have the same problem. I'm curious on what's going on and how to fix it too
Old Oct 26, 2011 | 10:01 PM
JC-RH's Avatar
i don't know how much more of the bracket I can trim before i lose the use of the screw. i think i heard somewhere that people relocate the tab to give more clearance.
Old Oct 26, 2011 | 10:03 PM
chink-ah-saur's Avatar
I bent mine up then cut
its stilld rubd with someone in the car till one day it stoped lol
Old Oct 26, 2011 | 11:27 PM
michaelhuynh13's Avatar
if you can take pic i can help you i had the same problem to but take some pics so i know what ur talking about so it can make it easier for me to help you is it cutting ur tires ?
Old Oct 27, 2011 | 02:17 AM
B_Lam's Avatar
Hey Michael, mine was cutting my tire. I bent it but it seems like once in a while it's still cutting. any chance of showing me how you fixed yours? or helping me fix mine
Old Oct 27, 2011 | 03:02 PM
4DGS's Avatar
Get the grinder out and grind it off.
Also correct your camber, you have about 3mm offset change due to that .5 degree of camber. 3mm can make the biggest difference when the suspension travels.
Old Oct 27, 2011 | 06:19 PM
JC-RH's Avatar
but why am i having the issue with the side with the more negative camber than the side with less? i'll keep grinding tomorrow.
Old Oct 27, 2011 | 08:46 PM
JC-RH's Avatar
i was just doing some research, and people with other different cars have also experienced similar issues. they claim that one side's offset is visually more flush than the other. they make it seem like the axle is not completely centered. am i just crazy here?
R350k5
Oct 1, 2015 08:41 PM
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
rping
Jul 26, 2015 09:53 PM
Soumilg
Jul 18, 2015 12:33 PM
