Lowering my G35 coupe
Old Dec 23, 2004 | 11:21 AM
GuLater's Avatar
I have a 2005 G35 coupe and want to lower it. What springs should I use?
Old Dec 23, 2004 | 12:26 PM
Msedanman's Avatar
O.F. Administrator
GuLater,
I moved your thread to the appropriate forum for you. (Wheels, Brakes, Tires, and Suspension). and left a redirect to here.
Welcome to G35Driver, congrats on the new G, and good luck with your mods.
GSM
Old Dec 23, 2004 | 07:28 PM
Raznips's Avatar
if i am going to get springs i will probably get tein s techs or eibach's
Old Dec 25, 2004 | 01:40 AM
accordfreak's Avatar
i have eibach's for sale.. used only 2 weeks..
Old Dec 25, 2004 | 12:17 PM
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
H&R springs nice smooth ride
Old Dec 25, 2004 | 03:53 PM
Gsedan35's Avatar
What oem sized wheels do you have (this tells me what 05 suspension you have?
1. What do you want out of the lowering springs, just a lowered stance?
2. If you wish for more then just lowering, detail what else your wanting.
3. Also mention how much you want the car lower, give a min and a max amount that will make you happy.
Old Dec 29, 2004 | 01:18 AM
RyanBeppu's Avatar
H&R's as well...
I too have H&R's installed on my ride and i'm very happy with their look and performance.
Old Jan 17, 2005 | 01:38 PM
GuLater's Avatar
I have ROJA 19 inch formula 7. 8.5 in front with 245/35/19 tire and 10.0 in rear with 275/30/19. I just want the gap gone but I do not want the ride quaility to go away. I would like a 1.1 in front and 1.0 in back.
Old Jan 17, 2005 | 02:27 PM
CLS2G35's Avatar
Gulater, Gsedan asked what OEM size wheels you had not aftermarket.
Old Jan 18, 2005 | 11:12 AM
g8tor20's Avatar
FGC's official flip flopper
I'll jump in because I too am looking to lower my 2005 coupe. I have the 19" OEM (Sports suspension) and am looking to lower it slightly (just to look more aggressive). I am trying to avoid the use of toe bolts, camber arm, coilovers, etc. Using the search feature, , I have discovered anything more than .7" will require additional expense. I am looking for something right around there but will avoid the H-Techs for G35 as the specs make the car handle worse (from what I can tell). Any thoughts? Thanks
Old Jan 18, 2005 | 11:25 AM
Mike_Deezy's Avatar
I would like to know as well. Recommendations?
Old Jan 23, 2005 | 08:05 PM
g8tor20's Avatar
Can anybody help with the 2005 coupe 19" sport suspension upgrade? Should I upgrade or keep it stock? I like the ride now but like a lower, more aggressive stance. Thanks
Old Jan 24, 2005 | 02:20 PM
Gsedan35's Avatar
In your case, Tein H-tech's ment for the 350Z. You will need to invest in either a $240 SPC rear camber arm/toe bolt setup or just the SPC camber and toe bolts for in think $180. A more performance driven choice would be RSR downsprings ment for the 350Z, but they would drop you too much to avoid the need for front camber arms. But Cusco does now have front camber arms out now for a respectable price, $389.
Old Jan 24, 2005 | 03:12 PM
The_Driver's Avatar
Looking to lower sedan
I'm looking to lower my sedan (enough to stay within spec or avoid spending extra money on additional camber kits)...and would like to keep the same or better ride quality. What would you or anyone else with an opinion suggest? I have the sedan with sport suspension.
thanks
Old Jan 31, 2005 | 12:41 AM
BaByG7's Avatar
Blue Interior Lights
Those blue interior lights look AMAZING. How did you do that? Where did you purchase those lights? How did you go about doing this? Please reply back. Thank You.
