Wheel spacer vibration
Old Nov 21, 2011 | 06:03 PM
zoop425's Avatar
I just got finished installing kday's 25mm spacers all around and the car looks way better! But, when I get over 60 mph, the steering wheels shakes pretty badly and sometimes at slow speeds the whole car shakes. I torqued them down properly and in the correct pattern. Any suggestions?
Old Nov 21, 2011 | 06:07 PM
black_gst's Avatar
do you have hub centric spacers and hub-centric rings for your wheels if they aren't the stock wheels
Old Nov 21, 2011 | 06:26 PM
zoop425's Avatar
they are the stocks (for the winter) and yes the spacers are hub-centric.
4DGS's Avatar
Take them off and see if it's still doing it.
Vibrations around 60mph is more than likely a wheel that is either bent or slightly out of rotation (weights could have fallen off throwing them out of balance)
The spacer vibration is usually felt at all speeds, not just 60+
Old Nov 21, 2011 | 06:53 PM
zoop425's Avatar
Could it be my alignment? I also installed rear camber arms/ toe bolts and went lower in the front so my alignment is defiantly crazy at the moment. I plan I getting it done tomorrow or wednesday so I will have them check everything out at the same time.
Old Nov 21, 2011 | 06:55 PM
aa2033's Avatar
i had this same issue
https://g35driver.com/forums/wheels-...er-review.html
I took my spacers off and now i still have the vibration. i wasn't getting it before i put them on. I think something on my alignment got messed up.
Old Nov 21, 2011 | 06:57 PM
4DGS's Avatar
It COULD be an alignment. Just have your shop check these things out
- Align (obviously)
- Wheels balance
- Bends
- seat the spacers with impact while cross torquing
Old Nov 21, 2011 | 06:59 PM
zoop425's Avatar
Thanks, I appreciate it! Im going to do that tomorrow.. Anyone know a place in Westchester NY that does lifetime alignments?
Old Nov 22, 2011 | 04:36 AM
4DGS's Avatar
No problem man, phone a few places a lot of the big names will do free alignments for a year type thing, but they aren't always the shops you WANT to take your car to.... if you know what I mean lol
Old Nov 22, 2011 | 04:16 PM
zoop425's Avatar
just got my alignment done. I am in spec with toe all around and my camber is -1.5 in the rear and -2.5 in the front. I also got my wheel/tires balanced and rotated. Still vibrating.. what do I do!
Old Nov 22, 2011 | 04:38 PM
4DGS's Avatar
Did you pull the spacers off and drive without them?
It could be a wheel bearing... but the car seems too young for that.
Old Nov 22, 2011 | 04:48 PM
zoop425's Avatar
no I didnt do that yet I guess I have a new project for tomorrow. If I pull the spacers and it fixes the issue, is there anything I can do to fix it with the spacers? I know about the copper wire trick but If im correct, thats only for hub-centric spacers where the hub ring moves.. which is does not on these.. should I look into a different brand?
Old Nov 22, 2011 | 05:07 PM
4DGS's Avatar
I would send them pack to manufacture and tell them to fix their product and send you a sound product.
obender66
18 Inch
Mar 13, 2016 12:20 PM
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
