The Official XXR 526 Thread *POST YOUR PICS*
Old May 7, 2013 | 11:32 PM
  #151
RelliKg35's Avatar
I just ordered a set of these 20x9 +13 and 20x11 +13 for my 08 g37s. Im dropped on H&R springs, and am trying to find out what tire sizes to run. Another guy on myg37 has these wheels and is running 225/35 front and 255/35 rear. I honestly dont care too much for stretch so what are my other options? i dont want too much lip exposed. Thanks
Old Jun 12, 2013 | 10:00 PM
  #152
shiftdowng35's Avatar
you should be able to run 245/35 & 275/30's if you just have h&r springs. it'll still have a little strech to it, but i don't dig on that 'about to pop off the bead' look either.
Old Jul 7, 2013 | 07:47 PM
  #153
ONE4ONE's Avatar
Originally Posted by dragonv
One4one do you have anymore pics? Looks good.
Originally Posted by GTX915
more pics!
[IMG][/IMG]
[IMG][/IMG]
Old Aug 25, 2013 | 03:14 PM
  #154
peewee626's Avatar
center cap..where do we get it for this rim
Originally Posted by TGMcCoy
^^ Same here^^ Do they sell the Infiniti centercap? Or did you fit the XXR cap with an Infiniti sticker? I don't see them for sale anywhere...
I'm going to pick up these wheels for my coupe, most likely silver, but leaning toward gold because my car is Ivory Pearl....
so did anyone get the answer to this ???
Old Aug 25, 2013 | 04:28 PM
  #155
Almightyone's Avatar
^^ See post 42.
Old Aug 26, 2013 | 12:00 AM
  #156
ONE4ONE's Avatar
I ordered mine from the Ukrain.
Old Aug 27, 2013 | 09:54 AM
  #157
Blackg3506's Avatar
Does anyone have these wheels and run 350z tein s techs? That was my plan but since one4one posted his pic I'm not sure if it'll be too low for these wheels or not
Old Aug 29, 2013 | 01:35 AM
  #158
g06driver's Avatar
I had a question and yes, i have been doing a lot of research....currently im lowered on tein s-techs (z) with the rear springmount mod running my oem rays with a 20mm spacer in the front and 25mm spacer in the rear. i recently ordered some xxr 526 wheels 20x9+13 f and 20x11+13 r. I am planning on swapping the spacers (put the 25mm up front and 20mm on the rears) and i will be running 225/35 f and 255/35 rear for some stretch. I will be getting my fenders rolled, my question is will I need to roll my fronts as well due to the spacers and will I even be able to run that setup with those spacers without a fender roll AND pull? Im trying to avoid a pull. I have been doing a lot of research and I see people have run 20mm spacers in the rear with just a pull and 25mm up front but im not sure if that person had a pull up front as well (saw it on 2 diff cars). I was also thinking about leaving the spacers as they are now with the 526 wheels but don't know if that's too much as I can't find anyone that has 25mm spacers on the rears with that width and offset. I want an aggressive look but I don't want to have rubbing issues as it is my daily driver in San Diego. oh, and I will also be running pretty much normal camber with no camber kit. any help would be appreciated, thanks.
Old Aug 29, 2013 | 09:49 AM
  #159
Blackg3506's Avatar
I'm just guessing at this but I think ur going to be way to aggressive with those spacers to not be rubbing without a pull. U might want to look at some smaller spacers. I'd go with something that isn't gonna give u too much negative offset and even then u might need to pull the fenders
Old Sep 5, 2013 | 12:54 AM
  #160
g06driver's Avatar
xxr 526 wheels
i just got a set of these bad boys delivered today I will post pics in about 2 weeks after they're mounted and my fenders are rolled. Oh, and I purchased different stickers for the center caps because i didn't want to rock the xxr ones that come with the wheels.
20x9 -7 (with spacer) 225/35
20x11 +13 255/35
Old Sep 12, 2013 | 01:42 PM
  #161
peewee626's Avatar
Where did you ...
Order the different sticker from??
Old Sep 14, 2013 | 07:14 PM
  #162
duhkorean's Avatar
Originally Posted by ONE4ONE
[IMG][/IMG]
[IMG][/IMG]
godddamn niceee
Old Oct 16, 2013 | 12:02 AM
  #163
Anna04g35's Avatar
xxr 526 fitment question
Helllo fellas,
I came across this thread and fell in love with the XXR 526
My question is, I found someone selling these rims with these specs
Front Rims are 20X9.0 +13 offset with over 3" Lip
Rear Rims are 20x11 +11 offset with a 5" Lip
I currently have a 04 G35 w/ G Eibach Sportline Springs w/ front and rear SPC camber kits, also with Z Tokico Hp Blues. I also do not have brembo brakes;
If I plan not to use any spacers, will I need to have my fenders rolled or pulled, add additional negative camber or stretched tires to get these to fit? Also what tires would you all recommend I get.
I would prefer not to have my fenders pulled or rolled.
If I do want that flushed look. what size spacers would you recommend?
Thanks guys, I love the G community! Any help would be gladly appreciated
Old Oct 16, 2013 | 05:50 PM
  #164
Shouldn't have to roll or pull the fenders without spacers. No extra camber and 225/35 and 275/30 tires.
Those have a little stretch but not much. 15mm spacers would be good all the way around. You
would need to roll the rears then or add negative camber. I have basically your setup without the
camber arms and I daily drive mine.
Old Oct 18, 2013 | 05:51 PM
  #165
Charr's Avatar
Not as sexy as u boys with the 20's but my 17x9s keep me happy in my sr20det 180sx
Annd maybe just a sneak peak of my 18" te37s on my rb30det r32 for bonus points
