19x10 for fronts?
Old Dec 14, 2011 | 02:04 AM
felixfalgui's Avatar
19x10 for fronts?
Hi, just wanted to get some help if anybody has tried putting on 19x10 rims with 255/35/19 tires on the front of a 07 g35 coupe. I tried searching but I couldn't seem to find a direct answer. The most I've seen people do around here is 19x9.5 for the front. Hope you guys can help me. Thank you!
Old Dec 14, 2011 | 02:13 AM
SAMzG35's Avatar
G35
AmateuRN what rims are you running if you dont mind me asking?
and any more pics?
Old Dec 14, 2011 | 02:23 AM
HenryLee's Avatar
I ran 19x10.5 +7 w/ 245/40/19, no problem..
Old Dec 14, 2011 | 03:17 AM
10s up front are cake
Ran 19x10-10
19x11 +5
And my current set up, 19x10.5 +3
Old Dec 14, 2011 | 04:06 AM
dmcelso's Avatar
are any of you running stock upper arms?
Old Dec 14, 2011 | 05:37 AM
VictoriousG's Avatar
Tons of room op just make sure you get your fenders rolled to be safe
Old Dec 14, 2011 | 05:43 PM
4DGS's Avatar
Henry, roughly how much room would you say you have from wheel to strut and how much camber?
Old Dec 14, 2011 | 09:01 PM
Got it. Thanks for the replies.
Old Dec 15, 2011 | 09:01 PM
idrive_MD's Avatar
Shouldn't be a problem if you have a good offset. I run 19x10+20 with 285/30 up front. I also used to run a 255/35 at one point as well.
Old Dec 19, 2011 | 11:50 PM
Sylvan lake V35's Avatar
I run 19x10.5 + 17 with 275mm tires stock arms still, I have a front camber kit but I haven't got around to installing them yet.
Old Mar 29, 2012 | 07:25 PM
susu510's Avatar
Talking
How low was your drop? I just picked up wheels with 19x10 +9 front, lowered on BC coils debating between 245/35/19 or 245/40/19 or something else with that drop? Because I Also want to adjust front camber a little, don't want too much negative camber
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
miata007
Aug 17, 2015 04:36 PM
mryogi
Aug 14, 2015 07:58 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
