Will these HREs fit my G?
Old Dec 17, 2011 | 07:27 PM
Raaaaaaaandy's Avatar
I have the ability to pick up a set of 20 HRE's for a great price... They are 8" up front an 10.5" in the rear. They are coming off of an SC430 which the sit flush on... Since HREs don't display offsets, will these work?
Will I need hub centric spacers? Or spacers in general?
I am looking to put these on an '06 G coupe, sports package, stock breaks.
Any insight would help...
Thanks
Old Dec 19, 2011 | 05:44 PM
4DGS's Avatar
Can you get me a pic of the SC?
The front is no problem at all and the rear is 99% chance of working. There is just a slim slim chance that the rear may be very aggressive.
One thing to keep in mind, if these wheels are a single owner (as in the guy with the lexus bought them new) then you're going to need to center bored out to fit the Nissan hub. Lexus uses a 56.1mm hub bore where as Nissan uses 66.1mm hub bore.
You'll probably want spacers in the front judging by the wheel width, but that can be determined later on.
Old Dec 19, 2011 | 08:39 PM
I couldn't get a picture of the wheels on the car, but I did get a serial number off each... Is there a way to tell by those?
Front, r5u20p296520
Rear, R5U20P357060
Thanks for your help!
Old Dec 19, 2011 | 10:58 PM
805350z's Avatar
No way to tell unless the owner does backspacing measurements. id stay away from having such a skinny wheel up front with a 10.5 in the back ( then again i cant see how the lip is on the front wheel)
Old Dec 19, 2011 | 11:41 PM
Sylvan lake V35's Avatar
+29 front offset +35 rear they are pretty weak offsets for a G
Old Dec 20, 2011 | 01:19 AM
805350z's Avatar
^this, and depending on price, you can custom build another wheel to your exact likings.
Old Dec 20, 2011 | 07:53 AM
Thanks for the help guys, they would cost me under $1k for the set... Still not worth it?
Also, I have a set of Volk CE28s 19x8.5 front and 19x10.5 rears. +22 all around, but one has a small bend and they could use a refinishing.
Think I should stick with those?
Old Dec 20, 2011 | 03:53 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Offsets are incorrect from car/car and the center bore on the Lexus is smaller than the hub diameter on the G. Doubt it will work.
Old Dec 20, 2011 | 06:17 PM
4DGS's Avatar
Holy **** 1k.... buy em and sell em.
If they are multipiece wheels they are worth $2000 easily.
Old Dec 21, 2011 | 11:13 AM
whoozyadaddy7's Avatar
^ +1 Goodness that's dirt cheap.... Buy em for under a grand then sell em to me for 1200 if you don't like them
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
dseet
Oct 11, 2015 12:40 AM
Claudiu
Sep 26, 2015 01:04 PM
