Interchanging Suspension G35/350Z
Old Dec 28, 2004 | 12:34 AM
aLL STaR gene's Avatar
I've searched but come up dry on this topic. Anyways, I have a G coupe and was looking to pick up some suspension that was made for a 350Z. I was told by some that the suspension will fit and by others that the rear perch on the G coupe is different. Does anyone have an answer for me so that I don't get stuck buying suspension that I can't use. By the way, it's a set of JIC FLT-A2's that I'm speaking of. Any help is greatly appreciated!
Old Dec 28, 2004 | 12:48 AM
Gsedan35's Avatar
They will fit without any issue's since the upper and lower mounting area's are 100% the same on G's and Z's. BUT, as the harshed known mainstream system for the Z or G, I do not recommend them, even if this means walking on a fantastic deal. As someone that has followed owner comments from Z owners running them, you would be better off if you have to stick with Jic, to buy the linear sprung Gcoupe version. Be very carefull and make absolutley certain your best served with ANY system using spring rates that stiff.
Their coilovers used to be at the top of my want list, but after reading about a couple of Z owners having problems with the dampners leaking and then seeing other reliability issues with S15 owners as well, I crossed them off my list.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
doakley92
Sep 25, 2015 12:58 PM
