Replace Rubber O-Ring for Volk Center Cap
Old Dec 23, 2011 | 02:46 AM
mephistomyhero's Avatar
Hi guys,
I've posted in the classifieds too, but does anyone know where I can get the rubber O-Ring for a Volk GT series Center Cap? I had replaced my tires and when they removed my center cap, the rubber O-Ring snapped. Any help would be appreciated! Thanks.
BTW, if anyone have a spare chrome Volk valve cover, I would like to buy one too!
Old Dec 23, 2011 | 02:53 AM
HenryLee's Avatar
I have a spare PM me.
Old Dec 24, 2011 | 07:01 PM
g35koupe's Avatar
Originally Posted by mephistomyhero
Hi guys,
You can get the required o-rings from any shop that sells hydraulic seals (e.g. plumbing or mechanical supply store). Typically, the o-ring that comes with the Volk GT center caps is a 3.5mm x 50mm o-ring. These are pretty standard metric sizes, and shouldn't cost more than a couple bucks each.
Old Dec 27, 2011 | 03:02 PM
Thanks for the size G35Koupe! That will help me in locating it. I did see this one on Ebay:
http://www.ebay.com/itm/METRIC-RUBBE...item870d3cbfac
If you do the pull down menu, it does have 3.5x50 mm. Will that work? Thanks!
Old Dec 27, 2011 | 03:24 PM
g35koupe's Avatar
^ That looks like it will work.
Old Dec 27, 2011 | 07:20 PM
g35koupe's Avatar
You might want to try the 3.5mm x 44mm just in case as well. Sometimes the o-ring material is a bit harder/softer so between the two sizes you should get what you need.
Old Dec 28, 2011 | 02:38 AM
OK, I'll order both the 44 and 50 mm. Thanks for the help.
Old Feb 13, 2012 | 07:22 PM
So, an update since I was asked...I ended up ordering both from the ebay seller and both looked like it would fit. I ended up using the 3.5mm x 44mm, only because it was hard trying to make the 50mm one to fit. The 44mm one was still pretty hard making it to fit, but I eventually did. In hindsight, if they had 3.0mm x 44mm, I would use that one. In the end though, the 3.5 x 44mm did fit, but will a lot of elbow grease!
Old Feb 22, 2013 | 08:39 PM
xyz's Avatar
xyz
bump for helpful information.
Old Feb 26, 2013 | 10:56 PM
G35sedan03's Avatar
g35koupe i have a set of TE 37s on my corvette, and the PCD is the 5x4.75 or 5x120.65 i bought them brand new from a forum member and he did not buy center caps for them. These are gloss black and do you have a cap that would match that?
also is the actual diameter where the cap goes the same as a 5x114.3 wheel? i have seen center caps listed on ebay but nothing ever for vette wheels per say.
obender66
18 Inch
Mar 13, 2016 12:20 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
neight
Aug 3, 2015 11:27 AM
