G35x Wheel Compatibility
Old Jan 16, 2012 | 11:33 AM
Bastone's Avatar
Hey guys,
I've tried searching but nothing comes up when searching AWD or G35x, and I've read through countless posts covering this subject, but it's still very confusing.
I have an '05 G35x and I want to run a staggered setup without messing up the AWD system. I jeep reading/hearing about how an X can run staggered, as long as the tires are within 3-5% of each other. I also hear that the X CANNOT run a staggered setup unless the tires are one size all-around.
My questions are as follows:
  • How exactly can one determine the 3-5% range when comparing different size front/rear tires?
  • I have 18" winters right now mounted on 225/45R18 all-around. I'm planning on running a set of coupe 18's that I just picked up, for the summer. The tires on them are 225/45R18 fronts and 245/45R18 rears. Will these work? Or will I need to change up the tire sizes?
  • Which tire sizes have you guys had experience running staggered on an X?
Any input is greatly appreciated.
The car in question.
Old Jan 16, 2012 | 11:52 AM
G35xTurbo's Avatar
The important thing is the diameter of the whole set up. I use the miata tire size calculator and then try to get the overall diameter of the tires to be as close as possible. I'm currently running a staggered setup on my 04 x with no problems. Here's a link to the calculator:
http://www.miata.net/garage/tirecalc.html
Old Jan 16, 2012 | 11:56 AM
G35xTurbo's Avatar
Here's some pics and specs for reference. Currently I'm running 245/40 18 and just stretched the rear tire slightly which barely causes a difference in diameter. The wheels are 8.5" wide in the front and 9.5" wide in the rear. Hopefully that helps a little.
Pics:
Cajuncowboy
Jun 21, 2021 09:47 AM
Pcruz
Aug 12, 2015 07:46 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
rping
Jul 26, 2015 09:53 PM
