Tokico D Spec ??
Old Jan 7, 2005 | 11:56 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Question Tokico D Spec ??
Anyone know if the Tokico D Spec are available as complete
kit with springs as they are with some other cars,
Or just the struts/dampers?
Old Jan 7, 2005 | 11:59 AM
jaspergtr's Avatar
no springs. they do work well with aftermarket lowering springs.
Old Jan 7, 2005 | 12:19 PM
InTgr8r's Avatar
Thanks,
I know there are two models available.
One for the Z & I think one for both coupe & sedan.
If my sedan is lowered to the ride height of the Z,
should I get the one for the Z?
Old Jan 7, 2005 | 03:54 PM
kenchan's Avatar
You should consider based on the weight differences of the two
cars and if you plan to carry many passengers.
Originally Posted by inTgr8r
Thanks,
Old Jan 7, 2005 | 04:20 PM
TonyZ_G's Avatar
same shocks im planning to get... not sure if they would fit in an 05 sedan.. would it ? the site says 03-04 g35s
Old Jan 8, 2005 | 07:18 PM
InTgr8r's Avatar
Weight difference is not really the issue.
Spring rates would be, but not in this case
I have the '04 sport sedan.
The Z, coupe & sport sedan all have the same OEM spring rate
314f / 342r
& D-Spec are adjustable for both rebound and compression damping.
(but not independantly)
I was thinking that since I'm lowered to Z ride height....
the length of the Z strut/shock would be more suitable?
Old Jan 8, 2005 | 10:21 PM
kenchan's Avatar
>The Z, coupe & sport sedan all have the same OEM spring rate 314f / 342r.
Interesting.
Old Jan 8, 2005 | 10:37 PM
Gsedan35's Avatar
I did not find a colation between ANY shock measurements that I took when I had 350Z D-specs in my hands that revealed the shocks were shorter in a meaningfull manner to oem sedan shocks. Which was weird given that oem Z shocks are shorter bodied then oem sedan shocks by 3/4" or so. I looked at body length and extended piston shaft length amongst other measurements, somewhere I have them written down.
On the issue of which version to get, buy the 350Z version. Why do I say that. Given that the 350Z D-specs I got a chance to drive on were not near as stiff as Tokico had led me to believe*. I would not care to find out that maybe, just maybe the G specific D-specs are valved softer still. Set at half way up their stiffness adjustment settings, they were just a bit firmer then the oem sport sedan and G coupe. Which is exactly what the owner wanted.
The D-specs offer a really nice ride and drive quality. The overwhelming sensation is that they spent a lot of time in R&D getting the valving down pat. Overall you quickly realize that your money was well spent, well that's what I say, they weren't my shocks I was simply graciously given a chance to drive the car home from the install location.
*What Tokico told me. They told me that the shocks would be adjusted to be a bit softer then oem 350Z shocks, just as firm or MUCH firmer. Thing is, I HAVE the 350Z suspension on my car, so I now exactly how stiff it's shocks are.
Old Jan 8, 2005 | 10:54 PM
kenchan's Avatar
How much do the 350Z struts go for?
Old Jan 8, 2005 | 11:15 PM
Gsedan35's Avatar
Tokico 350Z and G35 D-spec shocks sell for the same price. They show up on ebay for $499 shipped. Of course as alway's give a forum sponcer a chance to take the business and make the sale before you buy.
Old Jan 9, 2005 | 11:11 AM
InTgr8r's Avatar
Gsedan35;
Thanks again for your input.
My initial thoughts were to go with the Z model,
due to the expected difference in body length.
Evan though there is no difference in body length,
based on your experience it still sounds like the Z model is best way to go.
Thanks
Old Jan 9, 2005 | 03:44 PM
GoSooners's Avatar
I have the GCoupe versions and it's set on 3.5 in the rear and 4 in the front and it still seems noticeably stiffer than stock...not subtle. However, I did change both springs and shocks at the same time so maybe it's the springs that's causing the slight bumpy ride quality (from stock). I had it first set on 3 in the rear and 4 in front.
Old Jan 9, 2005 | 04:37 PM
kenchan's Avatar
Thanks. I guess with the benefit of having adjustability, the
D-Specs might be easier to use.
Is it really true that the G sedan, coupe and 350Z all use
314F / 342R rates?
Old Jan 9, 2005 | 11:24 PM
Gsedan35's Avatar
Thanks.
Is it really true that the G sedan with sport, coupe and 350Z all use
314F / 342R rates?
Yes.
This is a example of how a company MIGHT get the wrong idea. Eibach's development car for their sedan springs was a non sport, which uses springs that are 10% softer. So, if they were to claim the sedan uses softer oem springs, that's why. They didn't R&D the stiffer sedan with sport and wouldn't know any better.
I got the spring rates for all the cars by either outright owning the springs or by the kindness of forum members. I take several carefull measurements of each springs wire diameter, ouside coil diameter and the number of active coils. I would like to measure G35X springs and springs off a 05 coupe with the sport suspension.
Old Jan 10, 2005 | 12:03 AM
kenchan's Avatar
Thanks. Yeh, I read that the non-sport used softer springs but didn't
think they would use all same rates on the other 3, especially the 350Z.
