Volks SF-Winnings 19" Offset question??
Old May 24, 2005 | 06:06 PM
  #121
allforthecash's Avatar
Originally Posted by etang789
Bzabodyn, if i read your post correctly that means a +19 offset is the same as +29 offset plus a 10mm spacer? like the wheel position are the same after the spacer? is there any downside as using a spacer just in case it doesnt fit?
BZAbodyn is right....offset between 19 and 29 only comes down to LESS than 1/2 an inch..but....with my +19 in front...the blades of the rim SIT....and i mean SIT on the Brembo calipers...a pebble couldn't even get in there...its so tight..and looks hot.... :-)
Old May 24, 2005 | 10:22 PM
  #122
realgone's Avatar
Widdle ya into kindling
bump
bump....what does this mean?
Old May 24, 2005 | 10:47 PM
  #123
it means the rims are gona be bumpy on the road....that's all
hehehehehhee
Old May 25, 2005 | 01:03 AM
  #124
etang789's Avatar
well if i get the +29 offset for the front what wheel spacer do i need? or what kind/brand of wheel spacer do I need?
Old May 25, 2005 | 08:17 AM
  #125
sapzil's Avatar
do i have to roll the fenders with this setup?
front-19/9.5 +19 255/35/19
rear-19/10.5 +29 285/35/19
with brembos and eibach pro kit
if i do, what's the best setup for brembo and eibach without rolling the fenders????
Old May 6, 2007 | 03:59 PM
  #126
Pat3000GT's Avatar
I am looking to get a used set of Volk SF Winnings. I know very little about offsets or tire sizes, and need some advice. Here are the specs on the 2 sets I am looking at:
Set 1:
275/30/19x9.5 +25 in the rear 245/35/19x8.5 +29 in the front
Set 2:
19 x 9.5 with a +29 offset in the front (245/35/19) and 19 x 10.5 with a +29 offset in the rear (275/35/19)
What are the pros and cons of each set up? They are going on a stock G35 that will not be lowered.
Old May 8, 2007 | 01:56 AM
  #127
EEjiggapin0's Avatar
^^^from what i've read you won't need to roll your fenders at all with either set up, even if you lower it i doubt you will need to roll your fenders
the only pro i can think of is with the second setup is the size of lip, most people like bigger lips on their g for the rear rims, so you'd probably get that on the second set up since it's a 10.5" rim
Old Jan 12, 2008 | 10:19 PM
  #128
thrice944's Avatar
Randomn Thread Bump
So I read this whole thread because I am also planning on purchasing some Volk SF winnings and wanted to find out what offsets would be best for my 2004 G35 with non-brembo brakes.
I am thinking that the following setup would be the best looking for my car at stock height and would not cause any problems if I decide to drop my car an inch:
19 x 9.5 front +29 = 67mm rim depth
19 x 10.5 rear +29 = 80mm rim depth
However it seems that if I go with the following cheaper and smaller setup it is still possible to get a very similar lip size:
19x8.5 +23 (61mm lip vs 67mm lip of 9.5" +19 and 9.5" +29)
19x9.5 +17 (80mm lip vs 80mm lip of 10.5" +29)
I guess I am just asking what the big advantage would be for spending the extra money and getting the larger size wheels.
__________________
Old Jan 12, 2008 | 10:28 PM
  #129
thrice944's Avatar
Almost Forgot
Another thing I noticed is that when the SF winnings came out a few years ago, the prices appear to have been significantly lower than the current prices. Two people in this thread bough their wheels new for $2200 and $2300. The best price I have been quoted for these wheels in SF winnings in19 x 9.5 and 10.5 is $2680.
Am I missing something, because I thought that wheels would be less expensive after being on the market for a few years.
Old Jan 12, 2008 | 10:58 PM
  #130
Calvin's Avatar
Overglorified Altima
Volk Racing has raised their prices on all their wheels several times. They're still popular, so they can still charge an arm & a leg.
Old Jan 13, 2008 | 11:23 AM
  #131
realgone's Avatar
__________________
To give you an idea, here are my specs and a picture. You can see that there is a gap and lowering would make the appearance better, but my driveway has a concrete hump, and I don't want to hit bottom, maybe rip off my bumper every time I back out. The dish in the front is already not near as deep as the rear and I would not want to go much less. I love the view from behind the car with the 10.5, it looks badass. Not sure if the 9.5 would set flush, like with the 10.5. The stocks are way inside the fender wall, and my 10.5 set flush, it looks awesome.
I think I would spend the extra money and go with the bigger widths.
My specs are
Volk SF-Winning
19 x 9.5 front +19
19 x 10.5 rear +29
Tires
Michelin Pilot Sport PS2
245 35 19
275 35 19
Old Jan 13, 2008 | 08:35 PM
  #132
thrice944's Avatar
Thanks realgone
Thanks for your help. We have identical cars( same color and I have upgraded my bumper and headlights) so the pics are very helpful as my car will look exactly like yours when done.
I keep going back and forth between the SF winnings and the Work Vs-xx wheels. I love the mercury silver (better than the silver works) but I also really dig the style of the work wheels and the extra business seems to give the car a sportier look.
Old Jan 2, 2010 | 06:08 PM
  #133
realgone's Avatar
My specs are
Volk SF-Winning
19 x 9.5 front +19
19 x 10.5 rear +29
Tires
245 35 19
275 35 19
This is my car (above)
I was wondering, could these wheels be used on a 2010 Sedan. I need to get a 4-door car eventually. I keep putting it off because I love my car so much, but eventually I will have to sell it, plus, I am sick of 14-15 mpg. I have been looking at the new TSX's and I really like them, but I would love to keep my wheels. If they worked on the G37 Sedan, that would be perfect.
Anyone know?
Old Jul 12, 2010 | 03:04 PM
  #134
Anyone have SF winnings with +17 19x10.5 in the rear on stock suspension? I'm placing a new order for rims and getting different stories on whether the 19x10.5 +17 will rub on STOCK suspension..car will not be lowered.
Thanks.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
neight
Aug 3, 2015 11:27 AM
