Bolt Pattern 5x112 fit on my 2006 g35x????
wussupb0o is right, you can get a wheel adapter spacer with the 5x112 pattern.
Looks like you're wrong, tough guy.
OP knows he was hoping to just put the wheels on, sans 25mm adapter spacer/converter.
Wrong offset and wrong bolt pattern. why not just buy some cheap wheels like everyone is doing these days.
you know if the holes on the wheels are abit bigger than usual they will fit? i tried once and it did fit. don't be so mad bic boi
Wow, you've out Dbagged me. Only difference is, I'm at least right when I'm being an *** hole about something.
OP, You can either un adapaters ( but keep in mind the smallest you can safely run adapters is 20mm and you may not be able to handle the 20mm offset change) OR you can run wobble nuts. It's basically a nut with a free moving washer that allows the nut to grab the stud on a slight angle. However as someone said above the holes will need to be larger enough to have that little bit of play....
Your other option if you really want these wheels is have them drilled out, lots of wheel shops now offer this service for about $150 or so.
Any other questions just ask in the wheel and tire question thread stickied at the top of this section.
You can't run them without adapters, wobble nuts, or having them redrilled. Redrilling is pretty inexpensive though, and if the offsets and widths are good for your application in my opinion that's the best option.
Cajuncowboy
Jun 21, 2021 09:47 AM
Jiggerjuice
Aug 17, 2015 08:41 AM
