XXR 521 drama
Old Jul 12, 2012 | 10:56 PM
TougeMonsterG35's Avatar
XXR 521 drama
well i got a set of xxr 521's in 20x10.5 all around and i having problems with the rim hitting the front arch that holds the A arm.... anyone else having this problem???? how much clearance do you really need to have ??? i was thinking about getting a set of 10mm spacers but is that enough clearance???? im not going for hella flush just sorta flush lol
Old Jul 12, 2012 | 11:34 PM
Jaygotboost's Avatar
10mm front 15 mm rear
Old Jul 18, 2012 | 11:45 AM
DEMoLITIoN's Avatar
15mm spacer all around will give you that "sorta flush" look. You can even go all the way up to 25mm and fit with a roll or slight pull in the rear... depending on tire size.
joedaddy1
Jul 28, 2015 02:58 PM
ISMSOLUTIONS
Archived Sales
Aug 22, 2007 07:09 PM
Greeknasty
May 27, 2007 03:14 PM
smactagg
Apr 22, 2007 12:12 AM
