Widest tires on stock Ray 19's????
Old Jul 25, 2012 | 11:18 AM
aaron3719's Avatar
Wider tire slows the car right?
Old Jul 25, 2012 | 12:07 PM
maizer89's Avatar
yea after a certain width you're just making it harder on your car
Old Jul 25, 2012 | 12:09 PM
JaE35's Avatar
Moderator
G35 Sedan
Originally Posted by Batmans
245 fit fine on the 19x8 rim? I did not know that.
I'm confused. What does a turbo have to do with the width of the tire on factory 19" wheels?
I and many others run 245/40/19 all the way around...performs great on the sedan at least
Xet's Avatar
Xet
Depends on the situation and what you mean by slows the car. Wider tire has more friction and weight which can mean a lot more grip to put down power or handle OR it can just mean using more gas to go the same speed.
Old Jul 25, 2012 | 12:17 PM
Swivel's Avatar
Moderator
All you guys running 35 series, doesn't the car ride like crap? I bet you feel everything on the road and I would fear curb-age. I live in pot hole city in the great Louisville, KY area and I feel everything on 40 series.
245/35 sidewall height is only 0.15" less than 225/40. I run 245/35 front and 255/35 rear on my sedan; ride is perhaps a little firmer but no issues.
Old Jul 25, 2012 | 03:20 PM
herrschaft's Avatar
Traction...
The factory wheels are only so wide which limits size of tires you can put on them. Since most turbo kits can easily hit 400whp/400wtq, trying to prevent the wheels from spinning all the time with 255 street tires isn't going to happen.
Old Sep 21, 2012 | 04:59 PM
KingCobra's Avatar
I thought rears had to be 255/40/19 with fronts 245/35/19?
Is it bad to go 255/35/19 in the rears? Would love to keep the same ratio front and back
Old Sep 21, 2012 | 06:12 PM
jninja26's Avatar
Not correct. I went with a popular setup of 245/35/19 & 255/35/19..this stay's within the vdc's limits.
Old Sep 21, 2012 | 06:29 PM
KingCobra's Avatar
^ Ive never heard/read of that setup
255/35/19 is 2.6% too fast compared to stock
255/40/19 is 1.2% too slow compared to stock
Seems like the 255/40 is a closer match tho
Old Sep 21, 2012 | 06:57 PM
Frankieg35's Avatar
I'm running 225/245 35 with no issues, looks better too..
Old Sep 21, 2012 | 07:08 PM
jninja26's Avatar
It's up to you.
Old Sep 21, 2012 | 07:17 PM
KingCobra's Avatar
Is there a big difference in looks? Do you have any pics of your car?
Old Sep 21, 2012 | 07:32 PM
Frankieg35's Avatar
Yeah it's a big difference, no pics though, sorry..
Old Sep 21, 2012 | 07:59 PM
herrschaft's Avatar
245x35x19 & 255x35x19. No issues with the VDC and there's many people running that setup.
Old Sep 21, 2012 | 08:16 PM
  #30
Frankieg35's Avatar
Biggest is go would be 235/255..
