2003 G35 with brembos 18" STERN ST-2 Rims will i need spacers?
Old Jul 24, 2012 | 03:47 AM
cheesehead5775's Avatar
I'm kinda new to the whole spacer thing will I need spacers on my g35 if I go with 18" stern ST-2 rims. I think the offset is. 20. I do have Brembo brakes?
Old Jul 29, 2012 | 08:29 PM
EL-EE-ES's Avatar
Well first off do you have brembos? Second you need to find out if the wheels have a "pad" or "disk" that well clear bbks. Do you want to use the spacer to make the wheels flush or are you asking to see if you need spacers to clear bbk? Are you lowered? How wide are the wheels?
We need a little more info to help you out
Old Jul 29, 2012 | 08:59 PM
I do have Brembo brakes and i do not want to use spacers. I would like it to be flush. My Car is not lowered and the Tires i currently have are 225/45/18 & 245/45/18 i think.
Wheels
Stern Wheels
Style: ST-2
Bolt Pattern: 5x114.3
Offset: +20mm
Old Jul 29, 2012 | 09:12 PM
hologram's Avatar
It depends on the size of the wheel's disk. But in general at that offset you should clear.
Old Jul 29, 2012 | 09:14 PM
How would i find out what the size of the wheels disk is? Sorry for the dumb question.
Old Jul 29, 2012 | 09:45 PM
hologram's Avatar
They will clear but upon closer inspection, those are a 600 dollar set of ebay rims. I would save up some money and buy a decent set of rims that will be stronger, less prone to cracking and bending and better looking(imo).
Remember what you pay is what you get in terms of quality.
https://g35driver.com/forums/v36-bra...rn-wheels.html
Not any problems reported but over stock you'd be gaining over 5 pounds per corner...seriously buy better rims..
I'll share an experience I've had with cheapo rims. After I installed them on my old car(set of Koenig's) I got into a car accident where a truck bumped into me from the side into my door. The tire flew off the wheel causing me to lose control of the car and have my car totaled(rim also cracked in half). After that I told myself I wouldn't buy cheap rims again, and went with some Weddsports SA55Ms and hit a curb at 45 miles an hour as I turned into a corner to avoid another car...The wheels had a bit of a scuff on the side that was fixed by a wheel repair service, and the wheel had no damage other than some minor curb rash...
So remember you are getting what you're paying for
Old Jul 29, 2012 | 10:10 PM
Hey I appreciate the help! I just saw them on a car and liked them appreciate the update on quality I currently have OEM. Wheels so I might just keep those instead.
Old Aug 1, 2012 | 09:39 AM
FrankP's Avatar
This might be a good reference just incase you want to pick a set. great people to deal with.
http://www.wheelsanything.com/
Old Aug 4, 2012 | 12:08 PM
Thought about putting enkei AKP rims on but they have a 40 + offset will I have trouble with that heard that 40 offsets aren't good for coupes?
Old Aug 4, 2012 | 12:44 PM
EL-EE-ES's Avatar
Too high of an off set, you need something in the 20s or lower for a coupe with disk that will clear bbk
TWASkyliner
Feb 8, 2020 08:00 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
Rehman2009
Jul 27, 2015 03:23 AM
Chattzx
Jul 17, 2015 11:23 AM
