Longer Wheel Studs Advice
Old Jul 27, 2012 | 09:20 PM
sicem13's Avatar
So I think it's about that time when I need to increase the length of my studs.
I don't have spacers, but my rims are the Axis Se7en Mod and they have such a thick wall between the inside of the rim and the opening for the stud that it only allows about 30% of the stock studs to be accessible.
Since the stock studs are 42mm long, I'm thinking 60mm is the length that I need to go with. I don't want to have to get open-ended lug nuts either.
I've also read that ARP is the best; however, I'm not looking to race, I just want some stock-performing studs that are just a little longer.
Has anyone had any experience with these? http://www.enjukuracing.com/products...eel-Studs.html
They are Circuit Sports brand, which I haven't read too much about. I also am not positive if they will fit my car or not. I'm looking at the 14.25mm knurl size (I think ours is 14.3, so is that just 14.25 rounded up?). And the site also doesn't list if it's the correct 12x1.25 thread size that I need.
I've also came across these, by Ichiba: http://www.andysautosport.com/infini...i00000751.html
Again, these are the 14.25mm knurl size, so I'm assuming that means it's the stock knurl size of 14.3mm, just rounded up.
If there's a different option out there that is not nismo or ARP, and is 60mm long, I'd also be interested in hearing about that.
Old Jul 29, 2012 | 03:51 AM
Blue Dream's Avatar
I drove ttrank's car solo
The only advice I have is avoid the Ichiba, they're soft and will strip on you.
Old Jul 29, 2012 | 12:43 PM
sicem13's Avatar
okay good. I ordered the Circuit Sports ones, so hopefully those will work out okay.
Old Jul 30, 2012 | 03:53 PM
VMRWheels's Avatar
Hmm... For something like studs I would probably have just spent the extra on the ARP ones but hopefully the Circuit Sports work out.
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
si_driver
Jul 14, 2015 12:29 PM
