squeaking bushings from control arms after rain.......
Old Jan 18, 2005 | 06:17 PM
klg35's Avatar
now that the rains are gone in so-cal, i have this constant squeaking from what i believe is from the kinetix front control arm bushings........tried wd-40, worked for a day, then heavy duty silicone spray, also worked for a day and the god-awful squeaking/moaning came back.......how bad is it? let's just say you can hear it cruising down a flat pacth of road from inside the cabin! i would hate to put back the oem arms as that will just reintroduce the negative camber problems again.......inputs please!
Old Jan 18, 2005 | 09:00 PM
kenchan's Avatar
What does Kinetix say about that?
I would try lithium grease, but you'll have to remove the arm and regrease everthing.
Old Jan 18, 2005 | 10:16 PM
klg35's Avatar
haven't called kinetix.........yet........funny thing, as i was backing into garage this evening....that squeaking/moaning was there as i turned the wheel while car was not in motion, so, could it be something else as well?
oh yeah, did you ever resolved your massive rear camber issue?
Old Jan 18, 2005 | 10:23 PM
kenchan's Avatar
That could be your tires (not in motion just turning your steering wheel).
My massive rear camber issue? huh?
Freeman186
Sep 6, 2023 10:07 AM
jilljann1
Jul 21, 2020 08:12 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
TheBay
Sep 3, 2015 03:27 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
