Snow tires...225 65 R17 on g35x?
Old Sep 27, 2012 | 08:51 AM
smilez2656's Avatar
Can I run 225 65 R17 on my g35x for my winter setup at stock height...got a good deal on a set!
Old Sep 27, 2012 | 10:20 AM
joedaddy1's Avatar
if you must.. probably..
but i personally wouldn't..
Old Sep 27, 2012 | 11:37 AM
smilez2656's Avatar
I dnt care too much for the looks...just want it to perform well in the snow ....why wouldn't u do this setup ? Curious
Old Sep 30, 2012 | 12:43 AM
joedaddy1's Avatar
i assume that you have a 1st gen sedan..
first they are much taller than your stock tires.. and also a little wider..
although i doubt it'll make a BIG difference, but wider tires = worse handling in snow.. but since you have a X and winter tires. .shouldn't be an issue...
the biggest reason is that you are going to hate it.. the snow tires are going to handle much worse than you other tires.. MUCH softer side walls.. my car leans SO much around corner with my winter tires.. i keep my eyes on the forecast to take them off during the first heat of the year... and that's with stock size.. with 65 sidewall.. wow.. it's going to be worse..
let's just say that even toyota avalons don't have that high of a sidewall..
Old Oct 1, 2012 | 03:11 PM
VMRWheels's Avatar
I would pass, as they are a lot taller than stock. Cheap alternatives do not always mean they are better!
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AJC128
Nov 1, 2015 11:55 AM
TurTLe*
Sep 29, 2015 01:43 PM
Claudiu
Sep 26, 2015 01:04 PM
