Tire height on 19" Rays
Old Dec 5, 2012 | 02:52 PM
HoodSTar457's Avatar
Originally Posted by herrschaft
Quote:
Originally Posted by HoodSTar457
yeah but it would fit with no rubsun or any problems correct??? help thanks u
Yes, technically it will fit but street tires that wide are designed for a minimum wheel width of 9" from the manufacturers. The sidewalls will probably bulge, the rear end will feel more loose since the wheel will be allowed to "float" more, and I'm curious to know the chances of an oversized tire coming off the wheel if it were to go flat. Its easy, just buy a tire that fits.
yeah thanks for the tip... but having 245/35 on the fronts will it m
ake it bulk out too?
Posted from G35driver.com App for Android
Old Dec 5, 2012 | 02:57 PM
herrschaft's Avatar
Depends on the sidewall of the tire. I had a very small bulge when I had the Hancook V12's, but they have a soft sidewall. 245mm will fit fine on the fronts.
Old Dec 5, 2012 | 03:11 PM
Texasscout's Avatar
But you know, "it is better to "look" good than to drive good.
BTW, "You look Marvelous!"
Old Dec 5, 2012 | 04:18 PM
HereKittyKitty's Avatar
yeah but it would fit with no rubs or any problems correct??? help thanks u
I thought about this tire size but I have decided to go with 255/40/19 for the rears.
Old Dec 5, 2012 | 04:25 PM
Hmm I c but I wanted to go the widest for the rears. I saw a guy on here who did whst I wanted but I csnt find thr page anymore
Old Dec 5, 2012 | 04:34 PM
Originally Posted by neal@tirerack
I would suggest against that 265/40. A bit taller than what will fit w/out rubbing. The 35 series is a tad off also, but better. Best fit, and most commonly used, is the 275/35-19.
will this setup be okay for the car 2005 G 35 coupe on stock springs I wanted the front to be 245 / 35 / 19 and for the rears I would like to do 275/35/19 with this the setup will it cause rubbing or anything like that I was trying to go the widest tires thank you so much
Hey bud I was wondering if this set u on woukd work with no rubbing or problems I have a 05 g35 coupe on stock springs I wanted to do the fronts 245/35/19 and for the rea
Old Dec 5, 2012 | 09:14 PM
Texasscout's Avatar
Dude, you are not texting nor is this Twitter...
Old Dec 6, 2012 | 01:28 AM
sorry man i just need those answer and im done. ..
Old Dec 6, 2012 | 01:58 AM
Th3R3dStar323's Avatar
I ran 275/35/19 on my rear rays just fine. I ran 245/35/19 on the front respectively.
Old Dec 6, 2012 | 02:37 PM
Sounds good brother im gonna go for it.
Depravity
19 Inch
55
Oct 16, 2015 01:36 PM
cmesidewayz
Sep 29, 2015 09:28 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
realtalk21
Jul 20, 2015 09:07 AM
