G35 Sedan Rims????
Old May 1, 2003 | 01:56 PM
G35onsteroids's Avatar
G35 Sedan Rims????
I want 18's on my sedan what are the bigest tires i should go with 45???? 50???? where are some good places on line to find some good tire and wheel packages. Thanks
Old May 1, 2003 | 08:41 PM
ryoken's Avatar
Re: G35 Sedan Rims????
www.tirerack.com
www.discounttiredirect.com
Old May 5, 2003 | 11:53 AM
Gsedan35's Avatar
Your stock oem tires are 26.2" tall, try and get as close to that height as you can. Tirerack's site has specs for all their tires, where you can look of the height of the tire's your interested in. As a example, I went with 245/40-18 vs 245/45/-18, since the 45's are taller than oem, I did not want to take a performance hit. The 40's are within 2.3% in size of oem.
You can quickly run threw several tire size comparison's via the link provided at the top of this forum section, the thread mentioning wheel diameter's (should read tire diameters).
Old May 5, 2003 | 03:15 PM
PlatinumG's Avatar
I'm also considering upsizing my tires to 18. Can any tell me or clarify if 245/40/18 is the way to go without loosing performance or having the tire rub against the fender? I haven't decided if I want to play it safe by going with 245/45/18.
Old May 5, 2003 | 04:07 PM
jetcityg's Avatar
I'll be mounting 245/45/18's up front and 275/40/18's in the rear, in the next day or two... these tires have a diameter of 26.7, which is about as close as you'll get to the stock 215/55/17 (26.3), when upgrading to 18's. The 245/40/18 is an option as well...just slilghtly shorter than stock, whereas mine are slightly taller than stock. I'll post pics, and let you know as soon as I get them put on.
Cheers!
Old May 5, 2003 | 05:37 PM
alexgg35's Avatar
Sedan's VDC system supposedly cannot handle different-sized front and back tires.I have a sedan I was interested in the 18"oem coupe rims but they are 225/45R18 W-rated front tire and 245/45R18 W-rated rear tire so before buying your tires check that with your service assistant so VDC works propertly.
Old May 5, 2003 | 05:47 PM
jetcityg's Avatar
I could understand where a difference in tire diameter could cause such a potential problem. I'm going with a staggered 245/45/18 and 275/40/18; both of which have an identical 26.7" diameter. Using a 225/45 (25.9") and 245/45 (26.7") may be more of an issue.
Old May 5, 2003 | 06:28 PM
alexgg35's Avatar
Maybe the problem with the factory 18 rims is that are different in diameter, I'm only suggest that consult with your service advisor.
Old May 5, 2003 | 11:59 PM
jetcityg's Avatar
I agree, it's always a good idea to check.... I do appreciate the advice!
Old May 7, 2003 | 11:33 AM
jmaloneydo's Avatar
Anybody know if putting 20's on a sedan will affect the smoothness of the ride, and if so how much? Also, what is the largest width tire I can safely use on the sedan without a rubbing problem, I already know that infiniti says 225 but has anyone used 245 width without any problems. I'm planning on gettin some 20's with 245/35/20 tires and want to know if it will be ok. Thanks
Once you own the best, everything else is just the rest...
Old May 7, 2003 | 08:31 PM
gaklid's Avatar
<hr></blockquote>Got'em, they work great....
<hr></blockquote>
Ivory Pearl/Premium/Xenon/
Old May 7, 2003 | 10:35 PM
jmaloneydo's Avatar
Gaklid,
Thanks for the reply bro, and I saw your pic in the other thread, those are some PHAT rims, congrats. When I get mine I will post a pic as well. Thanks Again.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
BlackGee35
Jul 23, 2015 01:36 PM
