Wheels do not fit flush on the disc brakes
Old Jan 7, 2013 | 06:18 PM
MartyeeBee's Avatar
Originally Posted by mj_39
You can but you shouldn't, you may experience vibrations at certain speeds. Personally would source out hub rings before installing,
http://www.ebay.com/sch/i.html?_nkw=...at=0&_from=R40
Any local wheel and tire shop should have exactly what your looking for as well...
so here is something interesting that i found. i was researching the dimensions on the wheels i bought (since i dont have a micrometer to measure the wheel hub) and according to this web site
http://www.piaa.co.uk/wheels/wheels.htm (piaa super rozza dimensions under Nissan 350 Z)
if the information on the wheels are correct, then the hub is already @ 66mm which leads me to believe that the wheel should be able to go on without the need to buy the hub centric rings. am i right, or am i completly off the map...
Old Jan 7, 2013 | 06:22 PM
MartyeeBee's Avatar
Originally Posted by VMRWheels
What wheels did you get? Sounds like they have a hubcentric ring on them which is an easy fix.
i purchased PIAA Super Rozza wheels. 20x9 and 20x10. they do have a hub centric ring, but im not sure what the size of the wheel hub is (and i dont have a micrometer to measure it). i know the brake hub is 66.1mm and another member suggested I buy 73 to 66.1 rings...
Frankieg35
Mar 20, 2016 09:42 PM
Jussaku
Aug 4, 2015 12:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
realtalk21
Jul 20, 2015 09:07 AM
