wheel spacer stuck on the hub, help!!
Old Jan 14, 2013 | 07:12 PM
drikx's Avatar
i was trying to take off my wheel spacers today and i took off all the nuts but the thing wouldnt budge. I guess its from all the rust and build up but does anyone know what i can do to get this thing off my hub. thanks
Old Jan 14, 2013 | 08:42 PM
Dubi2087's Avatar
Either grab and flat head an tap the edges with it with a hammer or with the hammer hit the top middle and sides of the spacers. Once off bush hub and and some anti-seize to center bore that is where it normally gets sticks to.
Old Jan 14, 2013 | 08:54 PM
drikx's Avatar
i already tried that with wd40, that thing does not budge at all...
Old Jan 14, 2013 | 09:43 PM
4DGS's Avatar
Gonna have to just keep trying... I'm going to assume you over torqued your lugs and it's squished the metal.
What kind of spacer are these?
Old Jan 14, 2013 | 11:05 PM
Dubi2087's Avatar
make sure you clean the studs off since you sprayed WD40, Only reason I say this is because they will not torque down properly because they will keep slipping. Thats why I didn't mention any lubricate.
Old Jan 15, 2013 | 03:21 AM
drikx's Avatar
h&r's and i torqued it to 80 or 85, i only had them on for half a year. Im not sure how it got all seized up. i got the rear set off because i worked off the hole in the hub but still cant get the front set to move..
Old Jan 15, 2013 | 03:28 AM
Th3R3dStar323's Avatar
use a screw driver and a hammer like a chisel
Old Jan 15, 2013 | 12:53 PM
dukehotty's Avatar
If you didn't use anti seize gel this might be your problem.
https://g35driver.com/forums/nationa...mbdiggity.html
Old Jan 15, 2013 | 01:22 PM
VMRWheels's Avatar
+1
Give this a go, and good luck!
Old Jan 15, 2013 | 06:23 PM
saywat?'s Avatar
^fyi op was able to get all the lug nuts off
Old Jan 17, 2013 | 12:30 AM
FastCat's Avatar
Torch & hammer
Use a real lubricant, WD40 is a water displacement chemical
Old Jan 17, 2013 | 12:34 AM
drikx's Avatar
i finally got it off. took it to the shop. they had a machine that pulled it right out. took 5 minutes lmao compared to the few hours i tried hammering at it
Old Jan 17, 2013 | 12:36 AM
drikx's Avatar
to add on top of the few hours i spent aimlessly hammering it, i got a summons for working on my car outside my house. **** was ridiculous.
Old Jan 17, 2013 | 01:00 AM
4DGS's Avatar
Only in Ny eh?
Glad you got it sorted man, next time remember some anti seize!!!
Old Jan 17, 2013 | 01:07 AM
saywat?'s Avatar
How should anti seize be applied?
